  • 3
Sonos - Virtual Device
Guest deraaij
Guest deraaij
Update: Please use TCP as of version 3.x as os.execute has been depreciated. As soon as we are able to have custom headers I will update the LUA code.
Hi all,
For those who are interested I made a Virtual Device based on the new LUA feature (inspired on lua code for MIOS) which can control a sonos device. It uses curl but will change it when the http api is documented. Change the IP address accruing to your needs.
EDIT: Added additional comments from other post which I posted in this thread.
EDIT: Changed req.lua --> /tmp/req.lua which works with beta 3.423 & 3.424
Play
Stop
Pause
Previous
Next
Mute
UnMute
Volume – Not Working yet because we do not get the value off: _sliderValue_ @fibaro how does this work with Lua?
Example Text-2-Speech using LUA in a scene:
Remark: Play is initiated with the last statement to actual play the text (change it accordingly).
Example play song from network with LUA:
Remark: Play is initiated with the last statement to actual play the song (change it accordingly).
Example radio station via LUA:
Remark: Play is initiated with the last statement to actual play radio (change it accordingly). For now only the radio name is set.
Mark[/b]
Hi
I've tied to get this to work with no luck.
I added a virtual device with the IP to one of my Sons devices and the TCP 1400.
I the added a button, see image, I deleted all tailing spaces.
Nothing happens when i press the button, am I doing anything wrong?
Guest deraaij
    Hi
    add 0x0D0x0A0x0D0x0A at the end.
    I've tried that, didn't work.
    Guest deraaij
    you are sure there are no trailing spaces ? (only enters) and or spaces in front of a line?
    Nope nothing seams to work, here is how I'll do it:
    1. Add a virtual device
    2. Add a button
    3. Open sonos and start to play something on speaker 10.6.2.113
    4. Pause the music
    5. Back to HC2 and try the button
    6. Nothing happens
    I have 4 sonos speakers, I also attached the "raw" button input so that you can see that I haven't missed any spaces.
    Do I hav to do something with my Sonos system?
    Guest deraaij
    Can you start with a new virtual device? I had some issues in the past with ones were I deleted buttons.
    Hello Deraaj and all of you sonos users !
    with newest beta of HC2, I've seen the new field 'main loop'. That would be interesting to poll the volume value in order to update the slider position, but I've no idea on how to proceed... What request is to be sent to a player ?
    Also, I've got different icons for paused/stopped and 'any other cases' (
    ). I'd like to know the state of the player so to update as well the icon. Any hint ?
    Thanx in advance for your reply
    Edit : maybe could we even add in a label field the current music name
    I have done that 10 times.
    Can it be that I'm using the latest beta, 3.560?
    Hi Sonos bods,
    Can anyone advise if there is an add in framework for Sonos that can call a web api on key events?
    thanks
    Guest deraaij
    I have the same version and works like a charm.
    [ Added: 2013-09-10, 20:05 ]
    Hi Sonos bods,
    thanks
    Yes. you can "SUBSCRIBE" on the url "/MediaRenderer/AVTransport/Event" of your sonos. I have made a python script which fires a scene when my livinigroom zone starts to play.
    __
    thanks will go and investigate
    +1. This has been accomplished in Vera, but like lordyorik, i do not know how to proceed
    Guest deraaij
    Sorry I am quite busy, but example to get current state of a particular sonos zone:
    for volume:
    Hi Adv.Usr.deraaij
    Thanks for your posts on controlling Sonos via HC2 - really really helpful!
    Your last two examples I can't get to work though on a Virtual device via Lua...
    I'm getting a HTTP 500 Internal Server Error on the GetVolume example. Would there be any way you could point me in the right direction?
    Really appreciate your help!
    Guest deraaij
    Hi Adv.Usr.deraaij
    mhhhm strange I tested i with my virtual device and it works, can you post a screen print of your virtual device button (code)?
    Hi Mark,
    Thanks for replying... I've copied the code word for word from your example (for GetVolume) - just replacing with the IP address of my Sonos Playbar (192.168.0.155).
    I've attached the debug output (showing the error)...
    Here's the exact code I'm using:
    Thanks!
    Guest deraaij
    Ok found it. Make sure you delete all the trailing spaces on each line. When you copy paste it it gives you a unwanted space at the end of each line.
    Works great! I should have thought of that!!
    Guest deraaij
    Nice!
