  • 3
Sonos - Virtual Device
Guest deraaij
Guest deraaij
Update: Please use TCP as of version 3.x as os.execute has been depreciated. As soon as we are able to have custom headers I will update the LUA code.
Hi all,
For those who are interested I made a Virtual Device based on the new LUA feature (inspired on lua code for MIOS) which can control a sonos device. It uses curl but will change it when the http api is documented. Change the IP address accruing to your needs.
EDIT: Added additional comments from other post which I posted in this thread.
EDIT: Changed req.lua --> /tmp/req.lua which works with beta 3.423 & 3.424
Play
Stop
Pause
Previous
Next
Mute
UnMute
Volume – Not Working yet because we do not get the value off: _sliderValue_ @fibaro how does this work with Lua?
Example Text-2-Speech using LUA in a scene:
Remark: Play is initiated with the last statement to actual play the text (change it accordingly).
Example play song from network with LUA:
Remark: Play is initiated with the last statement to actual play the song (change it accordingly).
Example radio station via LUA:
Remark: Play is initiated with the last statement to actual play radio (change it accordingly). For now only the radio name is set.
Mark[/b]
yes.
1) I've created variables
2) I've imported file into new virtual device
3) I've entered IP to IP, and 1400 to port.
4) I've saved virtual device.
Alex57, what information appears in mainloop debug?
Superb job from Krikoff!!!
/emoticons/default_icon_eek.gif" alt=":shock:" />
I just tested this virtual device and wow!!!
Just one small thing - there was ~3-5sec delay when pressing buttons, can anyone think why it has delay?
Lauri
Trying to add an extra button for NightMode... can anyone see what i have done wrong? please help! So when i turn off projector the sonos playbar makes the sounds softer for normal day to day use and when projector on then i get full sound with plenty of bass etc...
POST /MediaRenderer/RenderingControl/Control HTTP/1.1
Content-Length: 281
SOAPACTION: "urn:schemas-upnp-org:service:RenderingControl:1#SetEQ"
010x0D0x0A0x0D0x0A
[ Added: 2014-06-21, 18:02 ]
Don't think this is possible looking at 3rd party api and wire shark
[ Added: 2014-06-21, 22:47 ]
worked it out
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> works now!
Can i please have your great plugin as well Krikroff? i get an accsess fault on the Domonique web site even if i have an account
Guest Paweł Świerczyński
    Hi i have one problem maybe somebody can help me with volume:
    this is my volume code :
    GET /jsonrpc?request={"jsonrpc":"2.0","method":"Application.SetVolume","params":{"volume":_sliderValue_},"id":16} HTTP/1.10x0D0x0A0x0D0x0A
    And its not working
    /emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />, all other button works perfectly but I still have problem with volume control....
    pathduck, you can download last version 0.0.7 at the bottom of my message.
    Original post is here
    Krikroff, this script works only with HC2 ( althought i can import this on hcl but totaly not work), by the way about HCL i use Test_Julien.vfib all works perfectly besides volume :/
    I have bridge and sonos 3 and 5. I want to make 2 virtual device and control speakers seperetly . With Test_Julien.vfib all works fine besides volume ;/
    Pablos321, yes my script only works on HC2
    Hi Krikroff,
    I have written a tutorial on integrating iKettle with Sonos on the Home Center 2. I have mentioned you and provided a link to your excellent virtual device in the article.
    Thanks for all your hard work which makes so much possible!
    The tutorial can be found at
    Adam
    Hi Adam, your tutorial is really nice, good idea and iKettle seems like a very interesting product. I hope it will arrive soon in France.
    Jean-Christophe.
    Thanks Jean-Christophe,
    I'm surprised that it isn't there yet. They have a friendly support team - I've asked them if they have any plans and I'll let you know what they say
    Kind regards,
    Adam
    I saw that smartthings and sonos can create a "scene" to group all speakers and play siren sound. Is this possible with HC? I guess we just need a button that can play a URL.mp3 file, any idea how?
    the code in smart things is as below for reference:
    [ERROR] 22:44:35: line 14: attempt to index global 'io' (a nil value)
    what is the problem ?
    Graba, you dont have that global variable on hc
    New version 0.0.8 at the bottom of my message.
    Change logs
    Improvement: Play TSS with auto stop mode (set dr parameter to "auto") now works as expected.
    Improvement: Play TTS with fidex duration (set dr parameter to "xx" seconds) now works as expected.
    Patch: Main image is now fixed after pressing a button, thanks to Labomatik & JM13.
    Patch: Bug with XMl parsing for BrowseDirectChildren.
    Warning: To operate the radio shortcuts you must choose at least two favorite radios.
    Dear people, I have SONOS3 and HC2 4.017 beta.
    Today I add my sons device to HC2, it's work better. Work play and mute.
    But how I can do scene talk SONOS for example temperature home or outside?
    Please help with new scene add code. And use this SONOS3 at talking speaker
    Thanks a lot.
    Hi all,
    This is superb, and great work for a beginner to coding like myself ! Thankyou everyone that is contributing, and thanks for the commented code !!
    I would like to get Jarvis to tell my son the weather in the morning .. does anyone know if there is a way to get the google 3.0 tts voices to speak the text ? Jarvis is in amongst it all
    Cheers,
    al.
