  • 3
Sonos - Virtual Device
Guest deraaij
Guest deraaij
Update: Please use TCP as of version 3.x as os.execute has been depreciated. As soon as we are able to have custom headers I will update the LUA code.
Hi all,
For those who are interested I made a Virtual Device based on the new LUA feature (inspired on lua code for MIOS) which can control a sonos device. It uses curl but will change it when the http api is documented. Change the IP address accruing to your needs.
EDIT: Added additional comments from other post which I posted in this thread.
EDIT: Changed req.lua --> /tmp/req.lua which works with beta 3.423 & 3.424
Play
Stop
Pause
Previous
Next
Mute
UnMute
Volume – Not Working yet because we do not get the value off: _sliderValue_ @fibaro how does this work with Lua?
Example Text-2-Speech using LUA in a scene:
Remark: Play is initiated with the last statement to actual play the text (change it accordingly).
Example play song from network with LUA:
Remark: Play is initiated with the last statement to actual play the song (change it accordingly).
Example radio station via LUA:
Remark: Play is initiated with the last statement to actual play radio (change it accordingly). For now only the radio name is set.
Mark[/b]
First of all, really nice job done!
Now for my noob question
/emoticons/default_icon_razz.gif" alt=":-P" />: can the TTS device after playing the TTS (or mp3) set the sonos back to continue what it was playing before the TTS interrupted?
I'm also very interested in this feature.
Robert
Robert
Same here
If Sonos or other UPnP device plays something controlled by UPnP, you can use UPnP commands to retrieve information, than start playback after TTS. But if Sonos actually plays something controlled localy (ex. from USB), than it can be a problem.
You can start any UPnP software at the PC (for example small and simple upplay program), and use it with Wireshark to scan UPnP commands and response. Programs as uppplay asks UPnP renderer device for status every second.
I did it with Denon AVR, and when Denon was controlled via UPnP, even from other device, I was able to see status and references of played file. But when I switched Denon to other source, it was not possible to use UPnP to check and control it. UPnP is not for that. Sonos plugin base on UPnP commands.
So I think it is possible to solve it, and have continuous play after TTS, but it would work in limited cases, can be also problem with playlist (or longer playback queue) etc. I think there is a chance that it would work with internet radio.
Hey there,
looks like all works perfect but i have a problem with my alarm system with the tts workaround.
I have a .mp3 alarm file that last for 3 Minutes.
My problem is that the file get played from both sonos players, but after 30 seconds it stops. Is this a limit for the tts workaround?
So i was thinking it just allows 30 seconds so i just tried to do a while and play the sound again. The problem is that it does just play the sound on one speaker and it ignores the others. Again after 30 seconds it happens that they switch sometimes and so on so it does not work as i want.
I really hope someone can help me here..
So still no solution for the Sonos and TTS?
In parallell im looking for a solution running a local TTS service on my osx server. Still running Krikroffs VD but using a local TTS instead of google.
But its not working... Any guidance?
I run the program M2S on my OSX server that response to HTTP requests like "
Rocks"
The request works running the request in a browser, the TTS comes out just fine.
I tried adjusting the Krikroff Virtual device with the proper URL like below but still get a return 500 on my HTTP request.
Tested change of VD (line 1320)
"<InstanceID>0</InstanceID><CurrentURI>x-rincon-mp3radio://10.0.1.10:8081/tts/?voice=Alex&text="..(urlEncode(message or "") or "message").."</CurrentURI><CurrentURIMetaData>"..Sonos:createMetaData("TSS by Google...").."</CurrentURIMetaData>",
Any pruposals?
Kristian
Hey there,
In the play function change the value off 10 in a higher value.
Now each value is arond 2 second so a value of 10 is around 20 seconds.
If you need three minutes you have to change this value to 180/2= 90 or a little less.
Also you can comment out the stop function.
while (currentTransportState == "PLAYING") do
          if (i > 10) then break end;
          getTransportState();
          fibaro:debug(currentTransportState);
          fibaro:sleep(2000);
          i = i + 1;
          fibaro:sleep(2000);
          i = i + 1;
this is brilliant and works perfectly well.
both methods tested and working.
Has anything been looked at for the Sonos Connect?  I am using the Fibaro HC2 plugin but it has limited functionality, such as being able to choose music source.  I am new to Fibaro (installed Monday).
Hello robotica,
have you've found a solution to playing Sonos Playlists or favourites yet?
Still can't figure that out by myself.
Best
Markus
hy all, Mark thx you for thoses soap code
since HCL dont use Lua VD, and with your help i manage to make sonos run.
i would like to know how do you manage those code, play, pause etc. cause actually i am trying to make this works with a Squeezebox .
thx
10 hours ago, Cannon_82 said:
Hello
Is there any chance to play a SONOS PLAYLIST?
greetings
robert
at the moment you need to use the sonos node api. which is installed on the pi
you can then use a VD to play the playlist.
see this excellent tutoarial here for more info:
  • -1
For me the problem is that I don't seem to be able to import VD, not only this one, but any.
When i upload it I onle get a HTTP 500 error, does anyone know what i'm doing wrong?
