Basic Code Clips for LUA starters
To help those that are not familiar with LUA a starter library of clips that work in Fibaro.
Please add any you find useful.
  • Answers 151
  • Created
  • Last Reply
HansW, yes that is a comment line but we took from that information for our scene engene
Cool!
Tested this one. Brilliant!! Many thanks
Is there a list somewhere of the Fibaro functions and their syntax to be used?. It works fine but I don't understand for instance what the fibaro:call(2,.. so the value 2, actually does.
Hans
Guest deraaij
Based on jompa68 code. I changed the code bit so it will:
* Run every 5 minutes
* Logs if it finds a device which is dead.
* Tries to wake the device.
* If waking the devices fails, send's an email.
* If no issues are found it also log's it.
BTW did not do extensive testing....
Cool!
Hans
the fibaro:call(2, "sendEmail",.... is the ID of users 2 emailaddress.
To see what id a certain user have you use
and search for the email address you want to send to and put that ID in after fibaro:call
[ Added: 2013-03-19, 19:44 ]
Battery Level and sendPush
Have not test it 100%, i don't have battery operated things
I made the following code for emailing all dead nodes in one email message. I don't want a separate email for each dead device in case of power failure.
This works. However, when the number of Devices gets larger (about 8 ID's in the Devices array) the system crashes. When I delete the SendEmail line everything works correct (including the fibaro:debug statement) and no crash occurs.
Is it possible there is a restriction on the number of characters in an email using SendEmail? Or maybe a bug?
Here is a simple code that will notify you when any window/door is opened and make additional check every 30 minutes to remind you if it's still open.
Good for cold winter days
Guest dsilletti
Cool!!!
Now that we can know names, better use names, isn't it?
Now a question, how to write in LUA that scene must run every 1 hour?
(I don't want to copy all the times the text generated by blocks and converted to LUA
/emoticons/default_icon_mrgreen.gif" alt=":mrgreen:" /> )
ok I got it, via fibaro:sleep(milliseconds)
Regards
Domenico
If i go LUA will that affect ALL my scenes or can i try it out on only the scenes i choose to switch to LUA?
Guest PJ
I used Jonny's code and changed it so it reports all battery operated devices and also sends push with information about all of them
I have one question - is it possible in this case to loop push command somehow, so it can be send using only one message (information about single device in new line)?
EDIT:
I use polish words in my code: nazwa=name, urzadzenie=device, poziom baterii=battery level - but it should be clear anyway.
Guest PJ
Thank you very much:) It just took me 10 minutes on google to search for function that append strings, just to find out I have to use ".."
I have not tested the max size of message you can push but would expect a limit.
Yep, that's right. I was able to make list for only 6 devices (with their names) in single push (but I have quite long names of devices :-> When I used only devices' IDs list could be longer) The problem is, that if there is more devices, it doesn't show any error. It just doesn't send push.
Guest PJ
Yes, that is very good idea, thanks.
Hi, I tested this code and it's working well. A question how to have name instead of id device in email/push sent?
Guest PJ
Just use fibaro:getName(i) instead of i
Where exactly in the code? Sorry I'm just starting to learn LUA code
/emoticons/default_icon_redface.gif" alt=":oops:" />
Guest PJ
Sorry, me too
This is correct code:
I changed it in these two lines:
fibaro:debug("DeviceID = "..i)
fibaro:call(2, "sendPush", "Low battery on id:"..i)
it should work now
Hi, I have modified a bit this code as in case of FGK door_sensors it was showing Slave devices with NILL battery levels. Additionally in case of Danfoss Thermostats if the battery is very low it shows the value 255. I also prefer to receive the info by e-mail. I hope it helps.
Guest dsilletti
Hi all,
how to add message to the emails sent by LUA?
with the previos code (e.g. the Dead Nodes code), only the subject of the email is provided,
I need to fill the email message too.
This can be very useful in my case using Clickatell EMAIL to SMS API, but can be the solution to provide in 1 single email a long text (to report all dead nodes or all battery op. devices with low battery, etc etc)
regards
Domenico
[ Added: 2013-03-28, 22:46 ]
Another question,
doesn't work?
Thanks in advance
Domenico
Use fibaro:call(2, "sendEmail", "Email subject", "Email content"), The text in the last argument is the content of the email message.
Another question,
doesn't work?
Must be elseif.
Guest dsilletti
Another question,
doesn't work?
Must be elseif.
thank you gilbert, the Email content works like a charm,
the elseif, insted, return me an error:
maybe I'm wrong... My scene should monitor 3 motion sensors and if armed and breached, send Notifications with the room name, then sleep 30 seconds (Usually motion sensors generate a lot of alarm in few seconds when motion is detected)
is this code correct?
regards
Domenico
look here
