Basic Code Clips for LUA starters
To help those that are not familiar with LUA a starter library of clips that work in Fibaro.
Please add any you find useful.
  • Answers 151
  • Created
  • Last Reply
/emoticons/default_icon_mrgreen.gif" alt=":mrgreen:" /> from 3.552+
we want 3.551+ lol
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> android push notifications! your already talking about 3.552+ wow you do move quick!
Looks like 3.552+ will be my "Super hero"
new virtual device for controlling holiday mode in all sections
chose slider and LUA from virtual device
Guest dsilletti
GREAT!
Great Socha!!!
It works perfectly!
Thank you very much!
Mario
in 3.552+ new wakeup function
example
Easy question for this group probably. How can I put a message in the event panel using Lua. I tried fibaro:log(put this in the event log) but that obviously doesn't work. What is the correct command to do this?
Hans
in virtual device
in scene
Thanks mr Socha. This gives messages in the scene (debug) window. I would like them in the Event Log. This will enable me to log when a particular event triggered etc.
So how can I get scene 'debug' alike messages stored in the Event panel, with a timestamp etc..
we don't have easy way to get that but you can use
give you info about it is open or not
give you info about connection
I have 4 heating sections, ID: 3,7,8,9
I have change your code at this place to have my own heating ID
id_sections = {3,7,8,9 }
The code works perfectly on the ID:3, but not for the others.
What I'm doing wrong?
Arbu-jl, move slider and tell me all info what you will saw under virtual devices
A.Socha
Results are:
- Trying for 3
- Status = 200
Pause
- Going to next section
- Trying for 7
- Status = 200
That's all
What I can see, If I send the slider value, without moving it 4 times, all my heating IDs change as expected. But I need to press 4 times on the slider....
Arbu-jl,
try this one
A.Socha
Results are:
- Trying for 3
- Status =
- There is no such section
Pause
- Trying for 7
- Status =
Pause
- Trying for 8
- Status =
Pause
- Trying for 9
- Status =
That's all, nothing has been changed on heating, values have not been changed...
[ Added: 2013-07-06, 12:05 ]
Sorry, my mistake, I forgot to change credentials...
Results are...
- Trying for 3
- Status = 200
- setting temp
- Holiday mode set Status 200
Pause
- Trying for 7
- Status = 200
That's all
Guest spazpeker
I have a horstmann hrt4-zw wireless electronic room thermostat with hrt4 asr-zw receiver
i can see them both in HC2 and the thermostat switches on and off the receiver
with the HC2 I can override the thermostat and turn on and off the receiver successfully
i have 20 floor temperature sensors connected to 5 universal sensor boards
what code do i use to overide the stat when my floor temp reaches say 32 deg
I want to make a Lua code to send push messages, where am I wrong??
fibaro:call(2, "sendPush", "Allarme Attivato", "Messaggio da FIBARO")
is it right? “does not work”
Sorry for my english
hi,
your device ID is wrong
go to the device api :
http:///api/devices
and get the id for the device you want tu push on.
the type is "type": "iOS_device" (For iOs and android)
Steve
Sorry
Because the code for sending email is working and the code to send Push does not work??
fibaro:call(2, "sendEmail", "Allarme Attivato", "Messaggio da FIBARO") => working
fibaro:call(2, "sendPush", "Allarme Attivato", "Messaggio da FIBARO") => Does not work
thanks in advance and Sorry for my english
Change "2" to a ID number of your IOS Device as suggested by Poppy.
2 is the User's ID not iOS device ID.
