Basic Code Clips for LUA starters
To help those that are not familiar with LUA a starter library of clips that work in Fibaro.
Please add any you find useful.
  • Answers 151
  • Created
  • Last Reply
rcanetta,
Probably you have started a few instances of the same scene. Stop the scene and Add the following code at the beginning before 'while' :
I hope it helps.
Hi, thanks - I have done the change
but unfortunately for some reason it only works on one window - also, strange enough it works only for sensor with id 38, even if for example sensor 46 was breached before 38.
Should I do one script per each sensor?
Thanks again!
Riccardo
OK here is my First Lua Script that i have been struggling to get it to work..... i know its not much for the expert users but i'm so happy i could make it happen..... Because of the fact that the heating panel does not have temperatures above 33.5 degrees ( which is a shame) i have tried to use lua code to control my heat pumps in order to heat my hot water storage tanks.... sensors are placed in side pockets of the tanks and the code turns on or off the pump...
Is this code ok???
i made the sleep function 15minutes right? so i do not power cycle the pump too often...
maybe there is another way to make this happen like add differential temp to the code...
on at 50 degrees and off at 60 for instance....
1000 =1s
so
15*60*1000
Ahh ok i see....
Thank you for your reply......
and using this script the temperature is monitored every time??? or is this scene runce once????
how do i make the scene run on time intervals??
i use timer for that??
christos
you got autostart so it works every 1s
better use "while do" with sleep option
PERFECT!!!!!!!!
So here is the revised code
Means that the scene sleeps for 2 minutes and executes the command
And with the help of the "optimise network" scene i make sure i don't have dead nodes.....
i'll leave this scene run for a couple of days and see how stable it is....
Christos
rcanetta,
It depends what you want to achieve. If you just want to be informed every 30 minutes which windows are opened then the code is fine and you should even remove the part:
If however you want to be informed immediatelly when the window is open and then every 30 minutes then the above code wouldn't work…
What do you really want to achieve ? I hope I can help you.
Hi Richo,
thanks for helping - ideally I would like to be notified immediately when each window is open and then receive a reminder after 30 minutes - the only way I can see to achieve this is to have a script for each window (?) but if you can see a better way...
Thanks a lot
Riccardo
Guest Kuuno
how to send push when HC2 starts.
thanks!
rcanetta,
It should be enough to have one script for all windows to notify about opening with the list of devices triggered and one for testing if it's breached every 30 mins.
[ Dodano: 2013-06-03, 15:01 ]
Kuuno,
try this:
Guest Kuuno
rcanetta,
Kuuno,
try this:
nope. there was "end" missing but still after reboot no push
what is the meaning of fibaro:call(2 <--
Kuuno,
2 means ID of your IOS device - replace with yours nr.
Guest Kuuno
Any way to change scene icons when triggering them
Eg when i presss play movie scene the icon changes to soemthing that reflects started scene
someone could help me for creating a LUA scene to activate / deactivate Holiday mode (and set reduced temperature) for a zone of heating panel?
For ex. Scene 1 = Zone 1 -> turn on holiday mode with temp 15°C
Scene 2 = Zone 1 -> turn off holiday mode and return to weekely program
I have already tried with the code wrote by Socha on this post, but for me it's not working...
Someone could help me?
Thanks in advance!
Read one page back
oh.. now two
/emoticons/default_tongue.png" alt=":P" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />
oh sorry... ehm. It should work. I have tried it. Tonight I can try to post my code... maybe I changed it a little.
Hello Stevenvd,
I've seen it, but I can't get it working... I can't understand what I'm doing wrong...
Please, could you post your LUA scene? So I can verify with my HC2...
Thank you very much!
mhh... that scene does not seem to be working anymore! haha. haven't used it in a while as I haven't been on holiday
If you figure it out... let me know
/emoticons/default_tongue.png" alt=":P" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> This is what I had in the scene:
please could you post complete scene?
Thank you in advcance
Bye
/emoticons/default_icon_mrgreen.gif" alt=":mrgreen:"> from 3.552+
/emoticons/default_icon_mrgreen.gif" alt=":mrgreen:" /> from 3.552+
Thank you so much for that
