iPad application is now released in Appstore
  • Answers 73
  • Created
  • Last Reply
@TANE: I'm logged in as admin. Still no scenes
@jonny: Took me a while to figure out, but when you're remote and get connection error, press the 'Edytuj' (no idea what it means) button. There you can supply remote access credentials.
edit:
D'oh, no scenes had the 'show in interface' checkbox. Lol, fixed
rb338, Edytuj -> Edit
rb338, do you got in scene "show in interface on yes?)
Great news!
I have downloaded and installed the app and have 1 bug to report.
The first time you open the App, it asks you to configure your Home Center 2 data.
If you leave all fields blank you get the following message"INFO: Wypelnij wszystkie pola", whatever that means
Anyway, please translte the message.
I'll test it when I arrive home.
Wypelnij wszystkie pola -> Please fill in all fields
Thank you for the information
If I find anything else I'll report here.
By the way, with the iPad APP released, should you not release a stable version of the HC2 firmware to go along with it?
Does not seem very logical to have your customers download the APP and then have to install a Beta firmware on the HC2...
NightShadowPT, report it on bugzilla
I have a spare iPad 1, which I have installed the wall mount bracket to wait for this new ipad application.
program, however, requires ios 6, so that's about it
Anyway, a great program.
Thanks Fibaro.
Many thanks Fibaro !!!
Is there any way to make it compatible with my old iPad 1.0 I have embedded into my wall ? (eg iOS 5.1.1) ?
Regards
2nd that,
i even bought specially for it a wall mount
whats the reason for using ios 6?
Regards
Fixed the issue with Remote Access, thanks for the suggestions.
It turns out you have to login locally the first time, then you have the option to setup remote. Not unreasonable to be fair, but not totally obvious.
Remote connection is often not available
Via remote camera streams are not available in the room but will work in the camera page
Over VPN all will work fine.
tried to control via internet, not LAN.
It appears to me that shutting or opening a roller shutter does not work via the IPAD app.
Via web using
... it's working for me.
Guest dsilletti
Hi, I downloaded the app from the Apple Store,
I am not able to connect my HC2, the ipad app shows always 'No connection, check HC2 connection', I can access HC2 from iphone app and from web, I tryied already to reinstall, reload HC2 but nothing, what's wrong?
Regards
Domenico
Update: I changed my password to a more simple one (the old cointained @ and other symbols) and now the iPad app can connect HC2 with no issues! (Both direct and remote connection works like a charm!)
Guest Dennis
2nd that,
Regards
Same HERE
+1.
used my "old" ipad 1 for the wall!
make it ios5 please
It will not work with iPad 1 the hardware is not good enough sorry!
How many software u already know not working on an ipad 1?
They worked 1,5 years on it and me is not happy, again they push us the invest on new hardware,
Why do You think that Fibaro push You to invest on new hardware? Do not You think it is Apple fault becouse iOS6 is not compatibile with iPad 1?I can only imagine how many new Api Apple used in new SDK which works with iOS6 and is still updating so do not blame Fibaro that they make apps using the best features with newest iOS system.
devriendtm,
Lol you are funny, fibaro don't have the choice. They do what apple want. That is sure, Fibaro is going to take money if you buy new Ipad. And I know a lot where is not working on Ipad.
Just tell me what kind of materiel thay forced you to buy with a gun on your head.
wasil,
+1
