iPad application is now released in Appstore
  • Answers 73
  • Created
  • Last Reply
I agree. This is Apple not Fibaro
all the new apps works only in IOS 6
Dear Users,
We would be very glad to support iPad 1 and iOs 5 as well. However the issue is more complex and iOs 5 and iOs 6 are so different that it would required completely different line and developing process. Moreover iPad 1 has limited system resources (with only 256 MB RAM).
Guest Martial25
is that the application runs on a mini iPad?
How Ipad is it best (mini, 3, 4)?
thank you
thank you
Work on iPad 2 - 3 - 4 - mini
When the stability in HC2 is back i will replace my Nexus 7 with a Ipad mini.
Please add also pan tilt to the camera in Room view
It's a realy beautiful App !!!!
Just One bug, i dont have Ipad...
May be this problem will be solved today...
How can i enable the RGB panel?
I have installed few RGB modules don't see them back on the Ipad.
not possible yet.
to bad..looks cool.
when will the next version available including the RGB control?
Guest Martial25
the application is very nice and works well. but would it be possible to add a pin code at the stop of the alarm
Vital to be honest!
Guest Dennis
+1 Great idea !
I have the same problem; if i connec via WIFI is all OK, if I try to connect via 3G the ipad app shows 'No connection, check HC2 connection' even if the user and password for remote access are correct.
Marco
Hi, I downloaded the app from the Apple Store,
I am not able to connect my HC2, the ipad app shows always 'No connection, check HC2 connection', I can access HC2 from iphone app and from web, I tryied already to reinstall, reload HC2 but nothing, what's wrong?
Regards
Domenico
Update: I changed my password to a more simple one (the old cointained @ and other symbols) and now the iPad app can connect HC2 with no issues! (Both direct and remote connection works like a charm!)
Marco
Regards
Domenico
I´m having the same problem and i do have a @ in the password.
will try to change it and let you know if it works. Anyway it would be great if Fibaro fix this in next update.
Best
Nuno
Marco
Regards
Domenico
Best
Nuno
My password is with letter and number.... but does not function...
No way to make this application work. Always the message "no connection". I have the iPad 3 and i'm on the 3.558 firmware. It's work good with the iPhone application.
edit: with no @ on the password, everything is fine
I find a bug in ipad APP.
control shutter,the "Pause" dosen't work.
some people have the same problem?
Forgive my English.
Guest Lode
I posted my problems in bugzilla.
I think it's easier for them.......
Thank you very much!
I posted it too.
Me too. I can only connect at home with the same LAN connection. Any connection outside the house either via WiFi or 3G is not possible
