Update 3.559 BETA
Beta version is designed for user testing.
WARNING! In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
3.559:
- Fibaro FGFS101 Flood Sensor support.
- Importing devices from other HC2 gateways (gateway connections).
- New virtual devices with support for iPad and Android apps.
- Changes dedicated to iPad v1.1 application and new Android application.
- Minor bug fixes.
3.558:
- RGB panel added.
- Fibaro RGBW Controller support.
- Added notifications (email and in UI) about devices low battery level.
- Support for iPad application and new Android application.
- Added possibility to sort sections, rooms, devices and scenes in configuration interface.
- New Event Panel - TimeLine.
- Possibility to move views in Dashboard.
- Possibility to change the type of binary sensor, e.g. motion sensor to smoke sensor.
- Information about last state change of the sensor (e.g. door).
- Fibaro Alarm panel added.
- Added possibility to reset device energy data.
- New languages: Russian, Danish, Finnish, Chinese.
- Bug fixes in showing and configuring power measurements.
- Bug fix in saving Advanced mode of GPS position reading frequency.
- Bug fix in showing information on the map in Family panel.
- Bug fix in VoIP panel - fixed logging in as system user.
- Z-Wave bug fixes.
- Aeon Labs 4in1 bug fixes (attention, in case of not working properly, device must be re-added to the system).
- Other minor fixes in UI and translations.
Bugtracker tickets:
- 0000080: Cameras do not display in IE10
- 0000200: Can't use a binary sensor as an input for bell push in video gate.
- 0000325: Parameter 42/45 representation of wallplug in GUI messed up
- 0000390: Rooms icon
- 0000419: Brak aktualizacji w zakładce pomieszczenia
- 0000488: fibaro:killScenes(ID) doesn't work
- 0000494: Wrong energy usage descriptions in energy panel
- 0000510: call wakeUpDeadDevice in scene seems not work as expected
- 0000515: Problem w wyznaczenia godziny wschodu i zachodu słońca
- 0000519: decimal points or comma's in variables panel
- 0000550: Don't mark as dead node option not saving
- 0000544: LUA 'Attention' dialog rendering
- 0000545: Improve alarm panel labels used in 'status' drop down
- 0000546: Device name length needs to be enforced when editing
- 0000556: złe tłumaczenie
- 0000590: Energy panel settings tab has a save button
- 0000596: Dashboard General Main sensors show Wrong DEAD
- 0000602: no ptz actions with a foscam like camera
- 0000647: Problems with setting associations
- 0000667: In dashboard view Danfoss thermostats are counted as dead
- 0000673: In General Panel on Dashboard all FGK101 Door/Window Sensors counted as doors even if change device kind to window sensor
- 0000678: fibaro:log not work in devices panel "/fibaro/xx/devices"
- 0000679: Aktualne zużycie energii
- 0000719: Can't use private icons for window sensor
- 0000769: Error message in dasboard
- 0000778: Missing translation
- 0000784: in german translation no values in devices configuration
  • Answers 86
  • Created
  • Last Reply
Guest deraaij
thnx, downloading!
Nice, downloading.
So now we can control other hc2 from lan ???
If nice, so good.
    yes and no, now you can control devices from other hc2 on your main hc2 by LAN
    Yes, it is what I want to say.
    Very Nice.
    Fibaro team +10000
    I am going also to test ipad.
    [ Added: 2013-08-22, 20:08 ]
    HC2 Gateway is very nice work very nice.
    I love the way to manage virtual device.
    Ipad: RGB device, work very good and same for virtual device.
    Really, really good upgrade.
    Next step for virtual device, return statetement from equipement and after virtual is going to be perfect.
    Nice work. Updating
    Hope the iPad app will be soon available
    RGB is going to be booming
    [ Added: 2013-08-22, 20:43 ]
    Looks like the RGB status problem is not solved with this version.
    slider will still turn to 100% even when the RGB is off
    "- Importing devices from other HC2 gateways (gateway connections).
    - New virtual devices with support for iPad and Android apps."
    Good job team
    A.Socha,
    On the main page, when you open virtual device to clic a button. This small panel don't get the name of the virtual device.
    Virtual Devices on iPad.....
    WOW!!!.... This is VERY powerful...
    Such a key component to the system... Well done!
    Yes, now that become interesting to have the status of xbmc or other device to turn on or off.
    Next step, have one buttonfor exemple to mute and unmute or full remote control by room.
    There is basic status information available through the button icons... If the HC2 is the ONLY interface you use to control, the icon will change to the last button pressed.
    i.e if I Pause Sonos, the icon changes to my "Pause" button Icon and stays that way until another button is pressed..
    Not comprehensive but easy to design controls around this so still a big step forward
    Yes, very good upgrade.
    Tomorrom I am going to work a lot of for pairing 2 hc2 and modify all my virtual device.
    I cannot access the Remote Gateway interface.. Does it only work if there is a connected HC2 on the network? It looks like there is an option to manually add a gateway
    (You can vaguely see the interface behind the spinning wheel)
    Anyone else having this issue?
    Guest b95_lun
    Great with virtual device support
    I don't see the virtual device response (fibaro:log in the lua code of the virtual device) after pushing it.
    b95_lun, because that is a log under device, to saw it on ipad, android you must use "label" and show that msg in it
    Nice work..Now I need to have the GlobaCache for turning on some devices.
    Like samsung TV, Dune player.
    Both can be controlled via IP but no option to turn on
    Dune player.
    Tane the Dune can be controlled, see the code I use (I use it for a power button: on when off, off when on). Change to the IP of the Dune.
    @Remko,
    Thanks will tray the code.
    There was no control for my device what I can remember. Dune Duo
    All the other options works fine.
    There are some modules that can be controlled..I tested in the past the on function. Hope it will work now.
    Guest Martial25
    after the migration,
    the interface of the iPad Mini (version 1) is very slow ?
    Nice update but all my back-upss They're gone
    Guest Kuuno
    can you give any samples on how to use the loop function. were to get the correct label id's and so on...
    thanks
