Update 3.559 BETA
Beta version is designed for user testing.
WARNING! In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
3.559:
- Fibaro FGFS101 Flood Sensor support.
- Importing devices from other HC2 gateways (gateway connections).
- New virtual devices with support for iPad and Android apps.
- Changes dedicated to iPad v1.1 application and new Android application.
- Minor bug fixes.
3.558:
- RGB panel added.
- Fibaro RGBW Controller support.
- Added notifications (email and in UI) about devices low battery level.
- Support for iPad application and new Android application.
- Added possibility to sort sections, rooms, devices and scenes in configuration interface.
- New Event Panel - TimeLine.
- Possibility to move views in Dashboard.
- Possibility to change the type of binary sensor, e.g. motion sensor to smoke sensor.
- Information about last state change of the sensor (e.g. door).
- Fibaro Alarm panel added.
- Added possibility to reset device energy data.
- New languages: Russian, Danish, Finnish, Chinese.
- Bug fixes in showing and configuring power measurements.
- Bug fix in saving Advanced mode of GPS position reading frequency.
- Bug fix in showing information on the map in Family panel.
- Bug fix in VoIP panel - fixed logging in as system user.
- Z-Wave bug fixes.
- Aeon Labs 4in1 bug fixes (attention, in case of not working properly, device must be re-added to the system).
- Other minor fixes in UI and translations.
Bugtracker tickets:
- 0000080: Cameras do not display in IE10
- 0000200: Can't use a binary sensor as an input for bell push in video gate.
- 0000325: Parameter 42/45 representation of wallplug in GUI messed up
- 0000390: Rooms icon
- 0000419: Brak aktualizacji w zakładce pomieszczenia
- 0000488: fibaro:killScenes(ID) doesn't work
- 0000494: Wrong energy usage descriptions in energy panel
- 0000510: call wakeUpDeadDevice in scene seems not work as expected
- 0000515: Problem w wyznaczenia godziny wschodu i zachodu słońca
- 0000519: decimal points or comma's in variables panel
- 0000550: Don't mark as dead node option not saving
- 0000544: LUA 'Attention' dialog rendering
- 0000545: Improve alarm panel labels used in 'status' drop down
- 0000546: Device name length needs to be enforced when editing
- 0000556: złe tłumaczenie
- 0000590: Energy panel settings tab has a save button
- 0000596: Dashboard General Main sensors show Wrong DEAD
- 0000602: no ptz actions with a foscam like camera
- 0000647: Problems with setting associations
- 0000667: In dashboard view Danfoss thermostats are counted as dead
- 0000673: In General Panel on Dashboard all FGK101 Door/Window Sensors counted as doors even if change device kind to window sensor
- 0000678: fibaro:log not work in devices panel "/fibaro/xx/devices"
- 0000679: Aktualne zużycie energii
- 0000719: Can't use private icons for window sensor
- 0000769: Error message in dasboard
- 0000778: Missing translation
- 0000784: in german translation no values in devices configuration
  • Answers 86
  • Created
  • Last Reply
hi all,
i can't acces anymore to my HC2 thrue home.fibaro.com since i have upgrade to 3.559beta.
does anyone encounter the same issue ?
Ps : love the new Virtual devices ! thanks Fibaro !
You should read all sites on this topic and You will know this beta doesn't support remote access through home.fibaro.com Fibaro team should make it working in next few days
ok, sorry, i miss that information.
/emoticons/default_icon_redface.gif" alt=":oops:" />
What made me wrong is that home.fibaro.com was working with older beta 3.556/3.557/3.558.
    elmips, yes they was, but for 3.550, 3.552, 3.553, 3.554, 3.555 there was no access by home.fibaro.com
    ok andrew, thanks.
    btw who was pressed right click in virtual device? (there where you wrote code)
    /emoticons/default_icon_mrgreen.gif" alt=":mrgreen:">
    haa! magic
    Ux wise maybe not justified
    /emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> but I like it!
    Since yesterday I don't longer receive notification on my iPhone when this was working well, do you know if there is a problem?
    Ah yes ! coooool ! it help right clicking on the code of virtual devices ! thanks !
    Guest deraaij
    Sorry I am trying to understand wat happens but I can not reproduce it?
    Hello to all ..... I'm having some issue connecting via iphone to the HC2 (3.559)
    Talking with A.Socha I've understand that there is no problem on fibaro and iphone must work, but i've tried connecting with two different iphone that have 2 different carrier and i've got problem in both case.
    I've also tried connecting remotely from a different DSL line (@ my work) with no success !!!
    Local connection are working with no problem
    There is someone else that have my issue ?
    There is some log that we can investigate ?
    Bye
    The problem will be fixed when the connection to the remote pc??
    Hello to all
    After two days of blackout , Today seems to work !!!!!
    I don't know why ... no changes made by my way !!!!
    Guest Lode
    I noticed that the app is much slower than usual.
    Other apps work normal.
    Lode, what app? and on what is slower?
    If I Add Sprinklers in Sprinklers Panel then it is not possible to delete it from home page (your house)
    olegarhas, that is not bug, you can enter to that device and change what it controlling from sprinklers to light for example
    Hi All
    The last upgrade is very interesting for me especialy regarding virtual device. Good job Fibaro team
    However, I have some remarks and suggestions to make it excellent for me...
    It is about label in virtual device :
    - is it possible to define an attribute to set the type of the virtual device. My concern is to display temperature from an ethernet controler but I would like to have the same display as for a normal temperature device. If I display a number into the label of a virtual device, it is small. Else is there a way to have the same font as for normal device ?
    - is it possible to define the delay for the execution of the main code to avoid execution each second. My code request ethernet card so it take some seconds so I don't know how the main code handle that ?
    I attached a file to show th difference between tempaerature from virtual device and "normal" one. It would be fine to have the same...
    Thanks a lot
    David
    Guest Lode
    Hi Andrew,
    The iPhone app is much slower then before. (3G connection)
    Everything is much slower, camera's, devices........
    Sometimes i can't get a connection.
    I tried some other apps that use a 3G connection and they work on normal speed.
    I don't know what causes the problem.
    I will try iPhone app with WIFI to see any difference.
    Ipad app works fast but i use that only with WIFI.
    we dont touch that part, so speed will be that same (if connection speed is that same)
    I am using v3.559 BETA and have the following code in a Scene:
    When I manually change the value of the Presence_DanHome variable via the Variables Panel the scene is not triggered. Is this a bug in v3.559 beta?
    Also, when I issue a HTTP PUT to http:///api/globalVariables the variable Presence_DanHome changes, but the scene does not trigger. Is this the same bug/issue?
    Many thanks,
    Guest Lode
    Maybe it's my 3G connection, i don't know but thanks anyway
