Update 3.559 BETA
Beta version is designed for user testing.
WARNING! In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
3.559:
- Fibaro FGFS101 Flood Sensor support.
- Importing devices from other HC2 gateways (gateway connections).
- New virtual devices with support for iPad and Android apps.
- Changes dedicated to iPad v1.1 application and new Android application.
- Minor bug fixes.
3.558:
- RGB panel added.
- Fibaro RGBW Controller support.
- Added notifications (email and in UI) about devices low battery level.
- Support for iPad application and new Android application.
- Added possibility to sort sections, rooms, devices and scenes in configuration interface.
- New Event Panel - TimeLine.
- Possibility to move views in Dashboard.
- Possibility to change the type of binary sensor, e.g. motion sensor to smoke sensor.
- Information about last state change of the sensor (e.g. door).
- Fibaro Alarm panel added.
- Added possibility to reset device energy data.
- New languages: Russian, Danish, Finnish, Chinese.
- Bug fixes in showing and configuring power measurements.
- Bug fix in saving Advanced mode of GPS position reading frequency.
- Bug fix in showing information on the map in Family panel.
- Bug fix in VoIP panel - fixed logging in as system user.
- Z-Wave bug fixes.
- Aeon Labs 4in1 bug fixes (attention, in case of not working properly, device must be re-added to the system).
- Other minor fixes in UI and translations.
Bugtracker tickets:
- 0000080: Cameras do not display in IE10
- 0000200: Can't use a binary sensor as an input for bell push in video gate.
- 0000325: Parameter 42/45 representation of wallplug in GUI messed up
- 0000390: Rooms icon
- 0000419: Brak aktualizacji w zakładce pomieszczenia
- 0000488: fibaro:killScenes(ID) doesn't work
- 0000494: Wrong energy usage descriptions in energy panel
- 0000510: call wakeUpDeadDevice in scene seems not work as expected
- 0000515: Problem w wyznaczenia godziny wschodu i zachodu słońca
- 0000519: decimal points or comma's in variables panel
- 0000550: Don't mark as dead node option not saving
- 0000544: LUA 'Attention' dialog rendering
- 0000545: Improve alarm panel labels used in 'status' drop down
- 0000546: Device name length needs to be enforced when editing
- 0000556: złe tłumaczenie
- 0000590: Energy panel settings tab has a save button
- 0000596: Dashboard General Main sensors show Wrong DEAD
- 0000602: no ptz actions with a foscam like camera
- 0000647: Problems with setting associations
- 0000667: In dashboard view Danfoss thermostats are counted as dead
- 0000673: In General Panel on Dashboard all FGK101 Door/Window Sensors counted as doors even if change device kind to window sensor
- 0000678: fibaro:log not work in devices panel "/fibaro/xx/devices"
- 0000679: Aktualne zużycie energii
- 0000719: Can't use private icons for window sensor
- 0000769: Error message in dasboard
- 0000778: Missing translation
- 0000784: in german translation no values in devices configuration
  • Answers 86
  • Created
  • Last Reply
You're welcome, HC2 become more and more fantastic!!! Now I try to understand LUA as I never did programmation before
/emoticons/default_icon_redface.gif" alt=":oops:" />
Assuming temp freezing and fire are for flood sensor because it does nothing here
Guest Lode
The version's terrific, but .....
Are there any instructions/documentation on the new virtual devices? Eg What's the"main" button do? How can I use the feature for lua "add on" to set the slider settings in my Sonos virtual device?
I'm a convert from the Vera camp, but finding the trial and error method a liitle trying
/emoticons/default_laugh.png" alt=":lol:" />
I also don't understand the meaning of the mainbutton, ........
The main button and a "value slider" (if you are using one) appear on the config page and on the ipad application so that you don't need to go into the device to execute basic commands..
I.e If your virtual device was only 1 button, you would be frustrated buy having to open the full device everytime for one "main" button
    JohnnyC, just press first icon in virtual device you will on main page get all virtual device w/o entering to him
    I know
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> I was just explaining main button to other users
    Guest Lode
    So by pressing the mainbutton it always executes/presses the FIRST button in your virtual device.
    Could be usefull but not always....but anyway the new virtual devices are AWESOME !!!
    You can select which button will be execute by the mainbutton inside advanced panel of the virtual device
    /emoticons/default_icon_wink.gif" alt=";-)" /> . Working very well and usefull
    Guest Lode
    Lolomail,
    Didn't see that again....i think i need some glasses
    Thx
    You're welcome, me I need to understand LUA
    3.559 is really a nice upgrade with those virtual devices available in iPad
    Andrew, a question for freezing temp, you receive a notification when any temp sensor is reatching 1°C or this feature is for new Fibaro folding sensor?
    Laurent
    Laurent
    I think new device as I set main temp sensor and freezing point to 40 degrees and nothing happened over 8 hours
    [ Added: 2013-08-25, 12:29 ]
    Take it back just been notified via aeon multi sensor that my loft was potentially on fire
    You went over 60°C?
    Haha no I set fire temp to 16 degrees to test
    deanrparry, you must set up it mannually for all temperature sensor
    Manually??? You can tick box in temp configs that is it no?
    yes but for all temperature sensors
    I understand by default the Fire is ticked already so it is already done
    [ Added: 2013-08-25, 14:46 ]
    Is there a timeout or does it rely on the wake up of the device? does hc check every 1 minute?
    [ Added: 2013-08-25, 14:48 ]
    I somehow fluked a fire report off a device i had actually forgotten about in the loft! but cannot get any other device to report now! maybe its these bloody aeon multi sensors again they are annoying me now!
    [ Added: 2013-08-25, 19:03 ]
    Ahhh I see it does work once when temp > value but not looped so it happens once until value goes under then greater again! This is why manuals help!!!! When's the revised manual out?
    Hi Andrew,
    Love the new virtual devices but trying to figure out how to use them is a bit challenging.
    One thing I would like to do is set a label text from a remote system.
    Is this call also in the web api?
    Also any way to set the icon from web api?
    thanks
    hi all,
    i can't acces anymore to my HC2 thrue home.fibaro.com since i have upgrade to 3.559beta.
    does anyone encounter the same issue ?
    Ps : love the new Virtual devices ! thanks Fibaro !
    hi all,
    You should read all sites on this topic and You will know this beta doesn't support remote access through home.fibaro.com Fibaro team should make it working in next few days
