Update 3.570
WARNING! In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
3.70:
- New json library in LUA.
- User icons in remote access.
- Z-Wave bug fixes.
- Fibaro FGFS101 Flood Sensor support.
- Importing devices from other HC2 gateways (gateway connections).
- New virtual devices with support for iPad and Android apps.
- Changes dedicated to iPad v1.1 application and new Android application.
- Other minor bug fixes.
Bugtracker tickets:
- 0000899: Can't turn off potential fire and freeze notifications
- 0000511: SP814 template (broken)
- 0000142: Everspring ST814
- 0000782: After HC2 restart/upgrade the RGBW module is shown as 'On' in GUI
- 0000882: Virtual Device popup
- 0000890: When setting new value for ID of a slider(not tested for other controls) the old ui..value tag in JSON is not removed
3.558:
- RGB panel added.
- Fibaro RGBW Controller support.
- Added notifications (email and in UI) about devices low battery level.
- Support for iPad application and new Android application.
- Added possibility to sort sections, rooms, devices and scenes in configuration interface.
- New Event Panel - TimeLine.
- Possibility to move views in Dashboard.
- Possibility to change the type of binary sensor, e.g. motion sensor to smoke sensor.
- Information about last state change of the sensor (e.g. door).
- Fibaro Alarm panel added.
- Added possibility to reset device energy data.
- New languages: Russian, Danish, Finnish, Chinese.
- Bug fixes in showing and configuring power measurements.
- Bug fix in saving Advanced mode of GPS position reading frequency.
- Bug fix in showing information on the map in Family panel.
- Bug fix in VoIP panel - fixed logging in as system user.
- Z-Wave bug fixes.
- Aeon Labs 4in1 bug fixes (attention, in case of not working properly, device must be re-added to the system).
- Other minor fixes in UI and translations.
Bugtracker tickets:
- 0000080: Cameras do not display in IE10
- 0000200: Can't use a binary sensor as an input for bell push in video gate.
- 0000325: Parameter 42/45 representation of wallplug in GUI messed up
- 0000390: Rooms icon
- 0000419: Brak aktualizacji w zakładce pomieszczenia
- 0000488: fibaro:killScenes(ID) doesn't work
- 0000494: Wrong energy usage descriptions in energy panel
- 0000510: call wakeUpDeadDevice in scene seems not work as expected
- 0000515: Problem w wyznaczenia godziny wschodu i zachodu słońca
- 0000519: decimal points or comma's in variables panel
- 0000550: Don't mark as dead node option not saving
- 0000544: LUA 'Attention' dialog rendering
- 0000545: Improve alarm panel labels used in 'status' drop down
- 0000546: Device name length needs to be enforced when editing
- 0000556: złe tłumaczenie
- 0000590: Energy panel settings tab has a save button
- 0000596: Dashboard General Main sensors show Wrong DEAD
- 0000602: no ptz actions with a foscam like camera
- 0000647: Problems with setting associations
- 0000667: In dashboard view Danfoss thermostats are counted as dead
- 0000673: In General Panel on Dashboard all FGK101 Door/Window Sensors counted as doors even if change device kind to window sensor
- 0000678: fibaro:log not work in devices panel "/fibaro/xx/devices"
- 0000679: Aktualne zużycie energii
- 0000719: Can't use private icons for window sensor
- 0000769: Error message in dasboard
- 0000778: Missing translation
- 0000784: in german translation no values in devices configuration
3.548:
- Changes related to new version of operating system repositories.
  • Answers 76
  • Created
  • Last Reply
Update in progress...
/emoticons/default_icon_smile.gif" alt=":-)" /> thanks
[ Added: 2013-10-03, 21:10 ]
updated, works perfectly, thanks
Guest fab971
Update OK.
Update OK...
But i have problem with personal icon on fibaro iPhone app...
They don't appear on fibaro app iPhone (device virtual and door fibaro module)
It is on 3.562 beta...
With this 3.570 it is the same problem... no personal icon on fibaro iPhone app
    algeroth, log in local first - only in local access app downloading icons
    Anyone else have trouble selecting only few things on history panel? It seems to check some boxes all the time for me..
    Updated ! All seems to work correclty.
    Just a everspring AD142 Dimmer Plug that start to blink.
    Disconnect and reconnect from the power and the ad142 work well now.
    How can i connect in local...?
    Because when i'm connecting to my wifi local network...
    I reset fibaro login distance access
    and then i can 't connect to HC2 just with HC2 login...
    i need the fibaro login...
    is it normal?
    All works fine..
    Me too, my ipad app work again.
    I find the problem ...
    In fact it was a problem with my Wifi router...
    It's work fine now!
    Thanks for help !
    all works fine...more or less...
    like a iPad in phone app now it crash and close when i open my ipcamera..some idea?
    this affect only after update...
    Guest eco-domodom
    Hello, since the update, my VIVOTEK camera no longer works. with my clients is the same! not happy!
    eco-domodom, checked on VIVOTEK A and it works local and remote so lease check it again or contact with [email protected]
    All works fine..
    No new issues
    I am running the stable ver 3.570 and Iphone 2.0. App connects to HC2 and works perfectly with Wi-Fi but does not work with remote connection (3G). However if I connect via Wi-Fi and then turn Wi-Fi off in the iPhone and then continue operating the app, it somehow works. This is very strange. Can anyone please help. I would really like my remote access back.
    dev246, we gonna change timeout for biiger in iphone and ipad app that should help you with 3g
    I have launched the update yesterday, updated, didn't restart... This morning I forced a restart ( cut off power ). Now it boots up, I can ping it, I can even get on the management web page which still gives me an "update status" so I can't even login.
    Also all leds are ON and stable on the HC2.
    What's this new issue?
    thamio, try restart HC2 again if that will not help use recovery disc and do update from 1.38 to 3.570 and recover backup
    if you got more questions please send them to [email protected]
