Update 3.570
WARNING! In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
3.70:
- New json library in LUA.
- User icons in remote access.
- Z-Wave bug fixes.
- Fibaro FGFS101 Flood Sensor support.
- Importing devices from other HC2 gateways (gateway connections).
- New virtual devices with support for iPad and Android apps.
- Changes dedicated to iPad v1.1 application and new Android application.
- Other minor bug fixes.
Bugtracker tickets:
- 0000899: Can't turn off potential fire and freeze notifications
- 0000511: SP814 template (broken)
- 0000142: Everspring ST814
- 0000782: After HC2 restart/upgrade the RGBW module is shown as 'On' in GUI
- 0000882: Virtual Device popup
- 0000890: When setting new value for ID of a slider(not tested for other controls) the old ui..value tag in JSON is not removed
3.558:
- RGB panel added.
- Fibaro RGBW Controller support.
- Added notifications (email and in UI) about devices low battery level.
- Support for iPad application and new Android application.
- Added possibility to sort sections, rooms, devices and scenes in configuration interface.
- New Event Panel - TimeLine.
- Possibility to move views in Dashboard.
- Possibility to change the type of binary sensor, e.g. motion sensor to smoke sensor.
- Information about last state change of the sensor (e.g. door).
- Fibaro Alarm panel added.
- Added possibility to reset device energy data.
- New languages: Russian, Danish, Finnish, Chinese.
- Bug fixes in showing and configuring power measurements.
- Bug fix in saving Advanced mode of GPS position reading frequency.
- Bug fix in showing information on the map in Family panel.
- Bug fix in VoIP panel - fixed logging in as system user.
- Z-Wave bug fixes.
- Aeon Labs 4in1 bug fixes (attention, in case of not working properly, device must be re-added to the system).
- Other minor fixes in UI and translations.
Bugtracker tickets:
- 0000080: Cameras do not display in IE10
- 0000200: Can't use a binary sensor as an input for bell push in video gate.
- 0000325: Parameter 42/45 representation of wallplug in GUI messed up
- 0000390: Rooms icon
- 0000419: Brak aktualizacji w zakładce pomieszczenia
- 0000488: fibaro:killScenes(ID) doesn't work
- 0000494: Wrong energy usage descriptions in energy panel
- 0000510: call wakeUpDeadDevice in scene seems not work as expected
- 0000515: Problem w wyznaczenia godziny wschodu i zachodu słońca
- 0000519: decimal points or comma's in variables panel
- 0000550: Don't mark as dead node option not saving
- 0000544: LUA 'Attention' dialog rendering
- 0000545: Improve alarm panel labels used in 'status' drop down
- 0000546: Device name length needs to be enforced when editing
- 0000556: złe tłumaczenie
- 0000590: Energy panel settings tab has a save button
- 0000596: Dashboard General Main sensors show Wrong DEAD
- 0000602: no ptz actions with a foscam like camera
- 0000647: Problems with setting associations
- 0000667: In dashboard view Danfoss thermostats are counted as dead
- 0000673: In General Panel on Dashboard all FGK101 Door/Window Sensors counted as doors even if change device kind to window sensor
- 0000678: fibaro:log not work in devices panel "/fibaro/xx/devices"
- 0000679: Aktualne zużycie energii
- 0000719: Can't use private icons for window sensor
- 0000769: Error message in dasboard
- 0000778: Missing translation
- 0000784: in german translation no values in devices configuration
3.548:
- Changes related to new version of operating system repositories.
  • Answers 76
  • Created
  • Last Reply
Ok that is too bad, beause I don't have MJPG on my camera, is for that can be good to have snapshot also.
    Shad, copy then jpg link to mjpg link
    /emoticons/default_tongue.png" alt=":P" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20">
    I didn't think that ^^.
    Ok Work now.
    Regarding SDeath camera problem - I have been having exactly the same issue with camera displays since about beta version 3.557, or maybe 3.558.
    I use 4 different models of Panasonic BL-Cxxx cameras, and they were working fine until the update a couple of months ago.
    Now, Internet Explorer sequentially presents a login window for each camera as the Fibaro homescreen loads. A successful login for each camera will display the image, but the image is static and does not update as it used to. Clicking on the image opens up the settings page, but no image displays at all then.
    Other browsers (e.g. Chrome) don't even present a camera login window and no images are seen.
    However iPhone/iPad/Android apps all work correctly.
    Something certainly seems to have happened to the desktop browser camera access...
    Yep that's the same issue as I have.
    I have mailed support, hopefully they can see what the problem is.
    All works fine with this new version, but I have a problem with virtual device that pilot scene for a french system "pilot wire". a script exemple for a button that turn off a radiator :
    Thanks for help
    pgondot, use lua for that
    or
    then
    but about pilot scene i dont understood what you want to do
    Thanks but finally that's works,
    Your code is "more pretty" i take it thanks
    but I've not image for "ON" with the FGS221 on the iphone interface
    pgondot, connect by wifi (local) then app will download icons
    The same thinks with a FGS211 I can't see the ON/OFF buttons, and I'm connect in wifi
    Iphone 4S with iOS7
    Guest MitchellOnline
    I use also Foscam camera's, they are all not working anymore....
    EDIT: I have found a fix, use this MJPG stream URL instead:
    Suddenly started to have a problem with the picture from cameras on Chrome browser. I have cleared the browser cache and restarted - didn't help
    On Safari and iOS works well ..
    I tried that too before but also doesn't work in Google Chrome.
    Guest biscowar
    Posted: 2013-10-11, 15:23 Everspring st-814
    Hi all,
    i have my Fibaro Sw vers. 3.570.
    I have 4 Everspring st-814 configured about one year ago with old version software.
    Today i hadded a new St-814 to my fibaro, but i can't use it as termosta for Heating Panel.
    Te sensor give me Temp and Umidity, but for some unknown reason i can't use it for startinf my heater.
    Something to suggest me?
    Ty
    [ Added: 2013-10-11, 21:17 ]
    Ok new info. Fibaro see the sensor like humidity sensor and not like multifunction sensor. Thete is any way to force it manualy?
    Please held hete is cold.
    Is there a script to overpass this situation. Please my house is cold.
    My system will freeze every few days since the update.
    Also waiting for the Ezmotion support..
    Any idea when new beta is out or alpha whatever is next as I still have devices missing including room stat which is a pain in the arse!
    Just thinking out loud here Fibaro team, isn't it possible that a lot of issues after every update come from incomplete updates?
    Wouldn't it be better to provide full firmware updates, instead of incremental updates. That might not be fully installed while doing the update?
    This way we also know for sure the correct files are present after the update.
    Does somebody have problem to include windows sensor. I try to add 2, but it detect them like sensor without and don't show type device or any else.
    Did You wake them up manually during installation?
    It don't ask me to wake that is the problem. So I try to add them many without remove. I remove and try again but it is same.
    Which HC2 version do You have?
