Update 3.570
WARNING! In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
3.70:
- New json library in LUA.
- User icons in remote access.
- Z-Wave bug fixes.
- Fibaro FGFS101 Flood Sensor support.
- Importing devices from other HC2 gateways (gateway connections).
- New virtual devices with support for iPad and Android apps.
- Changes dedicated to iPad v1.1 application and new Android application.
- Other minor bug fixes.
Bugtracker tickets:
- 0000899: Can't turn off potential fire and freeze notifications
- 0000511: SP814 template (broken)
- 0000142: Everspring ST814
- 0000782: After HC2 restart/upgrade the RGBW module is shown as 'On' in GUI
- 0000882: Virtual Device popup
- 0000890: When setting new value for ID of a slider(not tested for other controls) the old ui..value tag in JSON is not removed
3.558:
- RGB panel added.
- Fibaro RGBW Controller support.
- Added notifications (email and in UI) about devices low battery level.
- Support for iPad application and new Android application.
- Added possibility to sort sections, rooms, devices and scenes in configuration interface.
- New Event Panel - TimeLine.
- Possibility to move views in Dashboard.
- Possibility to change the type of binary sensor, e.g. motion sensor to smoke sensor.
- Information about last state change of the sensor (e.g. door).
- Fibaro Alarm panel added.
- Added possibility to reset device energy data.
- New languages: Russian, Danish, Finnish, Chinese.
- Bug fixes in showing and configuring power measurements.
- Bug fix in saving Advanced mode of GPS position reading frequency.
- Bug fix in showing information on the map in Family panel.
- Bug fix in VoIP panel - fixed logging in as system user.
- Z-Wave bug fixes.
- Aeon Labs 4in1 bug fixes (attention, in case of not working properly, device must be re-added to the system).
- Other minor fixes in UI and translations.
Bugtracker tickets:
- 0000080: Cameras do not display in IE10
- 0000200: Can't use a binary sensor as an input for bell push in video gate.
- 0000325: Parameter 42/45 representation of wallplug in GUI messed up
- 0000390: Rooms icon
- 0000419: Brak aktualizacji w zakładce pomieszczenia
- 0000488: fibaro:killScenes(ID) doesn't work
- 0000494: Wrong energy usage descriptions in energy panel
- 0000510: call wakeUpDeadDevice in scene seems not work as expected
- 0000515: Problem w wyznaczenia godziny wschodu i zachodu słońca
- 0000519: decimal points or comma's in variables panel
- 0000550: Don't mark as dead node option not saving
- 0000544: LUA 'Attention' dialog rendering
- 0000545: Improve alarm panel labels used in 'status' drop down
- 0000546: Device name length needs to be enforced when editing
- 0000556: złe tłumaczenie
- 0000590: Energy panel settings tab has a save button
- 0000596: Dashboard General Main sensors show Wrong DEAD
- 0000602: no ptz actions with a foscam like camera
- 0000647: Problems with setting associations
- 0000667: In dashboard view Danfoss thermostats are counted as dead
- 0000673: In General Panel on Dashboard all FGK101 Door/Window Sensors counted as doors even if change device kind to window sensor
- 0000678: fibaro:log not work in devices panel "/fibaro/xx/devices"
- 0000679: Aktualne zużycie energii
- 0000719: Can't use private icons for window sensor
- 0000769: Error message in dasboard
- 0000778: Missing translation
- 0000784: in german translation no values in devices configuration
3.548:
- Changes related to new version of operating system repositories.
  • Answers 76
  • Created
  • Last Reply
Guest Lode
Update done !
Everything seems to be normal
all works fine...more or less...
like a iPad in phone app now it crash and close when i open my ipcamera..some idea?
this affect only after update...
same for me
/emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> Foscam 9821w
    olegarhas, that is IOS framework problem not HC2
    I have the problem that my IPCams (Wanscam AJ-C2WA-C118 Foscam clone) don't show an image anymore in the web interface. But they work fine in the iPhone and iPad app?
    Always worked fine but I think since 3.570 they stopped working. Could also been since 3.562 BETA, don't know 100% sure.
    I am using Chrome for accessing the HC2.
    SDeath, in interfece you got image or in adv settings cam? can you clean cache of browser?
    No it doesn't show the image in either page, not under "Your House", device edit page, Dashboard.
    I did try to open it in IE, and at first it didn't show either but when I refreshed it asked for the IPCam login details in a IE pop-up then it started to work. Somehow anything changed in how the login details are send to the camera?
    I cleared the cache in Chrome.
    check login and password then in camera settings, maybe you dont send them
    if you gonna stil have problem with that please contact with [email protected]
    Yes I do.
    Checked them and re-entered them, as they were all still there.
    But same result.
    No image.
    ok, then please contact with [email protected] by remote access we will check that problem
    Fakro - ZWS230 motor still not working.
    Resetted,
    back to factory settings with my Z-Wave devices (Congrats on the new recovery interface... really neat)
    Now waiting for a new update.. PLEASE add a "Check for Updates" button...
    restoring the backup as soon as the update is done
    Regarding SDeath camera problem - I have been having exactly the same issue with camera displays since about beta version 3.557, or maybe 3.558.
    I use 4 different models of Panasonic BL-Cxxx cameras, and they were working fine until the update a couple of months ago.
    Now, Internet Explorer sequentially presents a login window for each camera as the Fibaro homescreen loads. A successful login for each camera will display the image, but the image is static and does not update as it used to. Clicking on the image opens up the settings page, but no image displays at all then.
    Other browsers (e.g. Chrome) don't even present a camera login window and no images are seen.
    However iPhone/iPad/Android apps all work correctly.
    Something certainly seems to have happened to the desktop browser camera access...
    Yes I do.
    But same result.
    No image.
    Same problem for me with the IPCam.
    However my custom "other model" camera settings *are* working nicely still.
    Do I also need to email support@ or has a common problem been found now ?
    I have just rised a glass of brandy for FIBARO and it's team
    It's been the easiest upgrade in 10 month. BRAVO !!!
    HC is working, iPhone working, iPad working :::
    budda, ccie4451, we gonna need that camera to be check problem (you can send me ip login password to check that - will do that in Monday)
    Guest AxelS
    after the update on the latest version, the whole HC2 is very very slow. E.g. turn on a lamp over the web interface or the new iPhone app needs about a minute and more.
    has anyone else this problem?
    Solution? Ideas?
    /emoticons/default_icon_neutral.gif" alt=":-|" />
    Axel
    AxelS, please contact with [email protected]
    Jep same over here, the system is terribly slow! No speed increase after reboot. Just cleared browser cache but no result...
    Camera's not showing in interface is also a problem here...
    Andrew,
    It have something I want to know with camera.
    I have a ubiquiti cam so I use snapshot. But on android app, ipad app or web interface, when I click on it to have big picture it nothing appear. But when it is small picture that work. Does it possible to do something ???
    Shad, small window that is jpg refresh every 3s, full window is mjpg so please check you mjpg stream
