Wall Plug - Still no custom icon, why?
An issue has been sent in with a desire to be able to change the wall plug icon, for me this is has huge WAF. Right now, the washer, coffee maker, and all the lamps has the same icons in HC2 (the wall plug icon) which makes it hard to distinguish.
Nothing has happened with the issue in a couple of months, doesn't anyone else want this? It should be an easy thing to fix..
  • Answers 76
  • Created
  • Last Reply
I think most of the people who are having an wall plug are using it for small amount of energy consumers.
So what is the point of using that custom icon who doesn't show that consumption.
/emoticons/default_icon_mad.gif" alt=":-x" />
That icon is only one way to use consumption monitoring. For example, LUA-codes can use information about consumption. There is usually no need for me to see it on the icon, I just want to use that information in automation, not for eye-candy.
Guest cyril
In one case i have replaced 6 Fibaro modules with Aeon only because of the picture.. For Europe is it also the wrong one...I don't understand what the logic of this forced icon is.
Guest Rating
Same with me! I've got several wall plugs for that i'd love to see different icons!
Because current energy metering icon is pretty useles crap, I have changed power on color to green and power off to red. I'd still like to get custom icons instead, because now I cannot see power consumption straight from the plug, which would be nice in some cases.
I have also just stopped buying more of these, because there is cheaper wall plugs with custom icons available. Which is quite sad, actually.
Guest Dennis
ok ok + 2
    Not a single update on the issue for more than two years.
    Shouldn't be so hard to implement.
