Update 3.901 ALPHA for HC2
HC2 3.901 Alpha
Alpha version is designed for user testing.
Installation shall be performed only after reading and fully accepting following terms.
CHANGELOG
- introduction to the plugins (Denon Amplifier, LG Bluray, ONKYO Amplifier, Philips Bluray, Pioneer Amplifier, Samsung TV, Sonos, Sony Bluray, Sony TV)
- new improved Z-Wave engine
- cooperation with Z-Wave locks
- extended functionality of sensors (tamper support)
- extended support of Fibaro Smoke Sensor
- extended support of Fibaro Motion Sensor
- possibility of hiding devices
- possibility of disabling devices
- multithreading
- many backend improvements
IMPORTANT
In order to update to 3.901 alpha Home Center 2 must be first updated to version 3.591 beta.
It is recommended to make a backup before updating to alpha version.
Downgrading back to stable requires full recovery and restoring backup.
UPDATE PROCESS
1. To update to alpha make sure that you are locally logged as admin on your HC2.
2. Type the following address in your web browser:
http:///services/startAlphaUpgrade.php?key=
and press Enter.
3. Update screen with progress bar should appear.
Please be patient whilst update to alpha version as it takes more time than usually because of conversion process.
DISCLAIMER
Fibar Group Sp. z o.o. allows free use of this software in its “as-is” condition. Fibar Group Sp. z o.o. disclaims any liability of any kind for any damages whatsoever resulting from the use of this software
This is an alpha release, and active development is on-going. The platform might be unstable and is not final and should not be used in production.
PERSONAL KEY
In order to get personal key necessary for update please provide us serial number and MAC address of your HC2 at [email protected]. Please also attach statement that you have accepted terms of disclaimer.
FEEDBACK
We will appreciate your feedback on our bugtracker at
Thank you for your interest in alpha version and willingness to participate in the development of Fibaro!
  • Answers 264
  • Created
  • Last Reply
Any News about a new Alpha or Beta Version ?
fuuss, we are still working on new alpha
Dear Fibaro team,
About H264 support? Any expected date?
When we will be able to create scenes without LUA choosing the color of RGBW? And not just on and off ...
Is there a reason why in Time Zones (config) North Dakota (not a time zone) is listed multiple times along with several other states. I know the US is big, but we only have 10 time zones.
Currently I'm running 3.901 and it seems to be working great. When a new general availability version comes out, will my config convert/upgrade to that new version or will I have to wipe and start from scratch? Just curious before I get crazy configuring scenes and such.
Thanks in advance!
mmdonnelly, we are still changing many aspect of system, when we are adding support for device it may need reconfigure to start use new settings, and that can change device id if device id is different then you need edit scenes/VD,
I have tested it with Remotec zxt-120, it is able to control the temperature of IR-controlled Air Con with some bugs.
In the dashboard it shows as a thermostat, with the current temp and target temperature and the AC modes.
For modes, it only shows undefined for most item and one shows the cooling mode.
There are no ON or OFF button, so you can only turn on the AC by changing the temp or changing the mode to Cooling mode. I am not able to turn of the AC.
Also the battery level is incorrect, it shows empty even I plug with USB power, causing battery alert on the whole system.
Please fix this bug as you come so close to fully support all IR AC units without any coding or without any wire!
Any news , when a new alpha or beta will be released , I am waiting for a lot of bugfixes and I really don't want to go back to the old version
Pointless asking
news: they are still working on the many bugs that have been reported, but they will release it as soon as it is ready
/emoticons/default_tongue.png" alt=":P" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />
Guest mofawzi
Hi, I have denon 1913 and it dosent work with alpha 3.901 denon plugin, no response at all. any idea?
Is there alfa or beta version for hcl? I am really need onkyo control
Guest Lode
Who is running the Alpha version for HC2.
I don't hear nothing anymore.
Did everbody downgrade to last stable version ?
No testing any more ?
It's so quiet..........
Who is running the Alpha version for HC2.....
I've tried the first alpha. It converted only half of my devices, so it was unusable. Though the working part looked promising. Support knows about the problem. Many bugs have been reported at
and they are "assigned". So... I'm waiting for "alpha two".
It's so quit from Fibaro on the forums. Are they stopped with the development of 4.x ?
Guest Lode
Usually after a calm period they come up with something nice....
There are 23 bugs reported in 3 months...that's not so much.
As far as i can see they have some new employees, i see some names i never saw before.
Everything is very stable now so i'm not really waiting but an update about things going on could be interesting .....
Andrew......maybe ?
/emoticons/default_laugh.png" alt=":lol:" />
Lode, it's more
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20"> and You will get many new functions, few new device support, many improvements that you will love. So believe me very soon you will have many things to tests
Guest Lode
I knew it
Thanks Andrew, i'm very excited !
Hi! I've just installed the alpha, every went well all my configuration is appearing except that all my devices have new nodes ids and therfore I have no control on them. I have restored my backup reinstalled the alphaa seconde time but it's still the same. Conversion probem? Did anybody else had the same issue?
