Update 3.901 ALPHA for HC2
HC2 3.901 Alpha
Alpha version is designed for user testing.
Installation shall be performed only after reading and fully accepting following terms.
CHANGELOG
- introduction to the plugins (Denon Amplifier, LG Bluray, ONKYO Amplifier, Philips Bluray, Pioneer Amplifier, Samsung TV, Sonos, Sony Bluray, Sony TV)
- new improved Z-Wave engine
- cooperation with Z-Wave locks
- extended functionality of sensors (tamper support)
- extended support of Fibaro Smoke Sensor
- extended support of Fibaro Motion Sensor
- possibility of hiding devices
- possibility of disabling devices
- multithreading
- many backend improvements
IMPORTANT
In order to update to 3.901 alpha Home Center 2 must be first updated to version 3.591 beta.
It is recommended to make a backup before updating to alpha version.
Downgrading back to stable requires full recovery and restoring backup.
UPDATE PROCESS
1. To update to alpha make sure that you are locally logged as admin on your HC2.
2. Type the following address in your web browser:
http:///services/startAlphaUpgrade.php?key=
and press Enter.
3. Update screen with progress bar should appear.
Please be patient whilst update to alpha version as it takes more time than usually because of conversion process.
DISCLAIMER
Fibar Group Sp. z o.o. allows free use of this software in its “as-is” condition. Fibar Group Sp. z o.o. disclaims any liability of any kind for any damages whatsoever resulting from the use of this software
This is an alpha release, and active development is on-going. The platform might be unstable and is not final and should not be used in production.
PERSONAL KEY
In order to get personal key necessary for update please provide us serial number and MAC address of your HC2 at [email protected]. Please also attach statement that you have accepted terms of disclaimer.
FEEDBACK
We will appreciate your feedback on our bugtracker at
Thank you for your interest in alpha version and willingness to participate in the development of Fibaro!
  • Answers 264
  • Created
  • Last Reply
Is this alpha will be avaliable this year?
p.s. I mean like normal release not like beta.
DimaStud, 8 month before end year so i should answer yes
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20">
We are preparing new alpha who will have less bugs and will be more stable (thank you again everyone who helping us improve it)
Thanks to fibaro to include us in alpha Testing , I really love to find bugs and improve this great system. The more people testing something , the besster the software gets.
Is there a possibility to became tester for future release too ?
Thaks for posting screen dumps ect. It's interessting to se, what the near future brings.
I see Nest plugin and a nest-thermostat icon. Can anyone tell whether og not Nest Protect - smok detector is supportet in 4.x?
Kind regards, Ulrik
candrea77, We got that device on our list TO DO but i can't say when we gonna add it
This is a very urgent request. Not only for me.
I am new to using the smart home, but when I bought the equipment, one of the requirements was to support the IR transmitters. Your system does not work with them. Frankly, I thought to buy vera just because they support ir
I totally agree, all my clients on hand simply cannot use fibaro because it does not support IR and therefore cannot control Air conditionings. Personally thinks I is worthwhile to support this as soon as possible. Cheers!
Guest Kuuno
we use itach devices and they work flawlessly. i dont see a reason for remotec....
Did I miss anything? Is there a corresponding alpha version for HC Lite too? Or is that coming later?
Is this new alpha going to be releast this week?
lukas.polivka, HCL will don't get alpha version
we don't planing release new alpha in this week
remotec also has a temperature sensor, itach only can send commands.
What kind of temperature sensor can i buy for HC2?
You don't need to buy a temperature sensor. As many devices support or have temp sensors:
Flood sensor
Smoke sensor
Motion sensor
Door sensor (optional)
@L3n1n
iTach from Global Cache is supported and works flawlessly, no need to use a Z-Wave to IR Converter
Flood sensor
Smoke sensor
Motion sensor
I know, but
1) Fibaro Motion sensor not in sale yet;
2) Door sensor + temp sensor quite compicated and strange design;
3) Use flood sensor as main temp sensor in living room - kind of strange choice;
4) Only smoke sensor seems reasonable...
but
You have to buy TWO devices (smoke sensor + itach), (double price)
you should have to configure wifi (not z-wave) for itach, provide both of them separate power (5v for itach, 12v for smoke), rely on stable Wi-Fi and so on...
Remotec ZXT-120 is one combined device, not depended on Wi-Fi, needs one power source.
and working in Vera..
Guest Lode
For me best choice is universal sensor and temperature sensor.
Alex57,
more than this Remotec has a built in code library you just have to choose and try!
And believe it, they have a very good technical support!
Guest Lode
Does anyone know how far samsung smart tv's are integrated in this new software ?
Only remote control wouldn't make al lot of sense to me but PIP for example and using this for an ipcam would make a lot of sense.
What are the possibilities ?
Did I miss anything? Is it normal that all my ZWave devices got messed up after upgrading to the alpha version?
Could you tell us which devices are on this screen?
That is exactly what I had... Per room on average 2 out of 4 devices had disappeared (Rough estimate). Reconfigure, add device, reboots, ... no luck. Dimmers, door sensors, anything. Nothing could bring them back to life. I thought this was normal for a alpha
/emoticons/default_icon_smile.gif" alt=":-)" /> I did a recover to 3.9 version. Everything fine except custom icons, which is expected behaviour. Maybe I'll try the second alpha when it gets released, since the many bugs reported in bugzilla seem to be resolved...
Fibaro RGBW, Danfoss valves (1 old and 1 new), FGD, FGS 211, FGS 221, rollet shutter v1, Door/Window sensor, Fibaro Motion Sensor, Fibaro Universal Sensor, Fibaro Smoke Sensro, Fibaro Flood Sensor, Secure SRT321, Aeon multisensor...
