Update 3.901 ALPHA for HC2
HC2 3.901 Alpha
Alpha version is designed for user testing.
Installation shall be performed only after reading and fully accepting following terms.
CHANGELOG
- introduction to the plugins (Denon Amplifier, LG Bluray, ONKYO Amplifier, Philips Bluray, Pioneer Amplifier, Samsung TV, Sonos, Sony Bluray, Sony TV)
- new improved Z-Wave engine
- cooperation with Z-Wave locks
- extended functionality of sensors (tamper support)
- extended support of Fibaro Smoke Sensor
- extended support of Fibaro Motion Sensor
- possibility of hiding devices
- possibility of disabling devices
- multithreading
- many backend improvements
IMPORTANT
In order to update to 3.901 alpha Home Center 2 must be first updated to version 3.591 beta.
It is recommended to make a backup before updating to alpha version.
Downgrading back to stable requires full recovery and restoring backup.
UPDATE PROCESS
1. To update to alpha make sure that you are locally logged as admin on your HC2.
2. Type the following address in your web browser:
http:///services/startAlphaUpgrade.php?key=
and press Enter.
3. Update screen with progress bar should appear.
Please be patient whilst update to alpha version as it takes more time than usually because of conversion process.
DISCLAIMER
Fibar Group Sp. z o.o. allows free use of this software in its “as-is” condition. Fibar Group Sp. z o.o. disclaims any liability of any kind for any damages whatsoever resulting from the use of this software
This is an alpha release, and active development is on-going. The platform might be unstable and is not final and should not be used in production.
PERSONAL KEY
In order to get personal key necessary for update please provide us serial number and MAC address of your HC2 at [email protected]. Please also attach statement that you have accepted terms of disclaimer.
FEEDBACK
We will appreciate your feedback on our bugtracker at
Thank you for your interest in alpha version and willingness to participate in the development of Fibaro!
  • Answers 264
  • Created
  • Last Reply
A.Socha,
So when I install the Alpha and my merten (outside) argus z-wave motion detector is working fine I am very happy.
If it is not working as supposed I can send you a message and than you are going to support the device in beta release? Please reply if I understand the proces of getting other devices supported by fibaro.
stevenvd, if i remeber corect greenwave was working ok but 1 device was hiden - then yes we can fix it
NorthQ - is still not finished so for him you must still wait
A.Socha i'm planning to get an irobot soon.
Can you tell me what model will be suported?
Thank you.
Hello Andrew,
The device itself works fine. But only the first device shows energy measurements. Support for the other 5 should still be fixed.
stevenvd, yes we can fix that now in that alpha, if someone gonna have that device let pm me later when we gonna check 1 wave of reported problems (now we got few confirmed bugs) Ty guys for testing
I have added a samsung add on. Now what? what does this do? where can i see it? only option i have is to delete it.
And for some reason Fibaro app on my android phone has now stopped working.
Kind Regards
Darin Bradfield
App don't work with it I think.
well that sucks. that was the main reason for me updating it.
Would be great if the Fibaro chaps could also work on the Marantz amplifiers.
Hello Andrew,
Whits device ar u talking about? NorthQ?
Greenwave power strip.
If anyone has tested the Onkyo plugin on the Integra series I would be very interested to hear any feedback
JohnnyC We have an Integra in the office and we will test it with the Onkyo plugin tomorrow.
Thanks Rich... Interested to see if anyone has a workaround for "Network standby power" for Samsung Tvs also... Or if we can reprogram the power button on the plugin to send and IR code through a separate IP device
I would love to see NorthQ power meter fully supported as well. It would make the energy panel so much more useful.
No magic wand sorry and no programmable button for ir... Yet?
Andrew, does coorporation with z-wave locks mean that the security/alarm command class is now implemented? So that for instance also this device could work?
First of all , thanks Fibaro Team for sending me the key faster than I check my email
First impression , I think the web interface is faster.
My aeon labs mini mote disappeared from my list of devices.
The iphone version, the android and the alpha tablet does not work with the wall plugs , they do not appear, or do not respond (tablet)
Some extra devices showed up , or have only a device id like 88.0.1 , 101.0.0
this is just a quick impression , but very good and currently stable , for an alpha version.
I also tried the alpha release but I'm now proceed to a recover
It looks great, interface is fast, new devices appeared, plugins sound goods (but I have no supported device to test it).
BUT... all my virtual devices screw up ! I don't know if I've got a migration problem or if it is a bug but all my LUA codes in virtual devices was melted. It's like one device get the code of another device for some buttons... and nothing work anymore.
Is someone else got the same problem ?
+100, same for me
When will we be able to create our own plugins? More flexibility in the UI seems one of the biggest advantages so far
