Update 3.901 ALPHA for HC2
HC2 3.901 Alpha
Alpha version is designed for user testing.
Installation shall be performed only after reading and fully accepting following terms.
CHANGELOG
- introduction to the plugins (Denon Amplifier, LG Bluray, ONKYO Amplifier, Philips Bluray, Pioneer Amplifier, Samsung TV, Sonos, Sony Bluray, Sony TV)
- new improved Z-Wave engine
- cooperation with Z-Wave locks
- extended functionality of sensors (tamper support)
- extended support of Fibaro Smoke Sensor
- extended support of Fibaro Motion Sensor
- possibility of hiding devices
- possibility of disabling devices
- multithreading
- many backend improvements
IMPORTANT
In order to update to 3.901 alpha Home Center 2 must be first updated to version 3.591 beta.
It is recommended to make a backup before updating to alpha version.
Downgrading back to stable requires full recovery and restoring backup.
UPDATE PROCESS
1. To update to alpha make sure that you are locally logged as admin on your HC2.
2. Type the following address in your web browser:
http:///services/startAlphaUpgrade.php?key=
and press Enter.
3. Update screen with progress bar should appear.
Please be patient whilst update to alpha version as it takes more time than usually because of conversion process.
DISCLAIMER
Fibar Group Sp. z o.o. allows free use of this software in its “as-is” condition. Fibar Group Sp. z o.o. disclaims any liability of any kind for any damages whatsoever resulting from the use of this software
This is an alpha release, and active development is on-going. The platform might be unstable and is not final and should not be used in production.
PERSONAL KEY
In order to get personal key necessary for update please provide us serial number and MAC address of your HC2 at [email protected]. Please also attach statement that you have accepted terms of disclaimer.
FEEDBACK
We will appreciate your feedback on our bugtracker at
Thank you for your interest in alpha version and willingness to participate in the development of Fibaro!
  • Answers 264
  • Created
  • Last Reply
I really hope it is designed that we can create our own plugins , If not that would really be a shame . With the power of this community Fibaro would get even better.
Are there some news on this ?
For me, everything seems ok, but sceneactivation from dimmers stopped working.
I have this scene:
%% properties
207 sceneActivation
%% globals
if ( tonumber(fibaro:getValue(207, "sceneActivation")) == 22)
then
fibaro:startScene(17);
fibaro:debug(tonumber(fibaro:getValue(207, "sceneActivation")))
And if I check it, it gives an error:
[ERROR] 17:45:53: line :debug (arg 2), expected 'string const &' got 'nil'
Lauri, check id of devices for sure, if you gonna have still problem create on bugzilla new report
I can't rely understand way u haven't fix better sms country support? If u haw so extremely much sms problem to get it to work in Sweden and other country's way don't u fix
in stead it has a grate API and I crown it works because I us it on my Vera 3, can u pleas answer my question pleas
mh, Andrew I am trying to send you a pm but it is stuck in the outbox...
I have now installed the Alpha version. How can I help to get the full support for the greenwave power strip?
[ Added: 2014-03-28, 18:30 ]
mhh, I got many dead device. Devices not updating status and all the sensors now have all child devices double.
- Sonos is only half supported.
- Philips smart tv is not supported.
- multimedia devices not available to control in Scenes (not lua or graphic).
- Greenwave devices not even the first plug is updated anymore..
- API has changed. So many external applications don't work
- Alarm still not visible in dashboard
+ Smoke sensor now has "blackbox" functionality
Oh and there seems to be something quite wrong with the wattage... the light is off but using a lot! and strange kwh..
wait a bit and later wakeup all devices then from that momenst should be ok
wrote what you want more
that is introdusion so not all our mulimedia plugins are in that firmware
in blocks yes you can't use them but in lua you can (hints from the left menu are not completed but functions are working)
we dont have that device so we can made for him xml like i was said before (can be a Tuesday?)
api is that same (we was added few new functions)
yes but that can be done later
Thanks for your response! oh, I am sometimes a little hard in the feedback, but better feedback than no response right? I think you guys are doing great work and I know it is not easy to build so just trying to help
for the sonos, being able to group other sonos devices that you have in the FIbaro system should be possible...
One great item that should be possible but maybe still difficult. You have probably tried sending the google translate to the sonos?! that works great... if that could be implemented, or a lili like audi stream to the sonos. than it could be implemented in scenes. Than you can just select a notification and have it send to the sonos system...
Philips support is done by jointspace. some info can be found here and if you need I could help:
Is it correct that the horstmann are not working anymore?
A.Socha,
I try update on other HC2 and got Upgrade Error: 8.
What can I do ???
Why is my everspring door sensor removed?
[ Added: 2014-03-28, 19:07 ]
holy *
If you press reconfigure device. most things are removed and it is seen as a whole new device Which is called Main_Zwave_device with not working (values not showing) child devices.
And the system is very very slow! it has removed several devices and some are just dead and won't wake up.
Shad, restart hc2 and try again
stevenvd, thx for the info about plugins
- yes right now horstamnn not working with heating panel
- how you get that power values? what that is a device?
- yes that is not bug now every zwave device as a father got that device, when device is configured then it is hidden, so when you reconfiguration device old device is removed from hc2 and you see zwave device, next zwave adding it again to system , when it will be complete zwave device will be hidden again
The power happens when I switch a device from the greenwave power strip on or off.
The horstmann is not shown as a device at all any more but as this:
[ Added: 2014-03-28, 19:49 ]
So also no child devices, and not possible to change the temp. ALso icons can't be found by the system
go to configuration -> zwave-> and chek on autoconfiguration for batery devices, next wakeup horstamnn rest will zwave will do
Do anybody known if this Fibaro HC2 firmware coms whit a new remote update firmware?. If yes what firmware update do it haw? Fibaro wall plug?
Andrew - do Fibaro plan on allowing device buttons to be overridden. For example the Power button on the Samsung TV plugin needs to be redirected to send a command to a Global Cache IP2IR? (As samsung TV does not support WOL).
Also, is it possible to add buttons to a plugin? For example the Fibaro standard SamsungTV plugin does not have dedicated SLEEP or PICTURE MODE buttons (both useful functions).
Finally - is a Philips Hue plugin planned?
Thanks!
My z-wave network is constantly crashing. The LED is constantly lid sometimes as well...
Can u upload a pic of ur blackbox and al the fire alarm setting page please
Is there a list which Denon receivers are supported? I've got a AVR-1912 which i had hooked up with other scripts just fine but the plugin for denon doesn't do much at all. Cant even turn it on or off. My settings are fine, i can use the web panel of the denon just fine and use it when its turned off too.
If plugin is installed where can i see it as remote etc??
Another problem, HC2 was working ok, but today morning I had this image:
Have to restart, or unplug... as restarting doesn't work for me. than I just get a 503 for ever
Thanks after many upgrade, it is ok.
Edit: About ZXT-120 and h264, do you have some news??
