Update 3.901 ALPHA for HC2
HC2 3.901 Alpha
Alpha version is designed for user testing.
Installation shall be performed only after reading and fully accepting following terms.
CHANGELOG
- introduction to the plugins (Denon Amplifier, LG Bluray, ONKYO Amplifier, Philips Bluray, Pioneer Amplifier, Samsung TV, Sonos, Sony Bluray, Sony TV)
- new improved Z-Wave engine
- cooperation with Z-Wave locks
- extended functionality of sensors (tamper support)
- extended support of Fibaro Smoke Sensor
- extended support of Fibaro Motion Sensor
- possibility of hiding devices
- possibility of disabling devices
- multithreading
- many backend improvements
IMPORTANT
In order to update to 3.901 alpha Home Center 2 must be first updated to version 3.591 beta.
It is recommended to make a backup before updating to alpha version.
Downgrading back to stable requires full recovery and restoring backup.
UPDATE PROCESS
1. To update to alpha make sure that you are locally logged as admin on your HC2.
2. Type the following address in your web browser:
http:///services/startAlphaUpgrade.php?key=
and press Enter.
3. Update screen with progress bar should appear.
Please be patient whilst update to alpha version as it takes more time than usually because of conversion process.
DISCLAIMER
Fibar Group Sp. z o.o. allows free use of this software in its “as-is” condition. Fibar Group Sp. z o.o. disclaims any liability of any kind for any damages whatsoever resulting from the use of this software
This is an alpha release, and active development is on-going. The platform might be unstable and is not final and should not be used in production.
PERSONAL KEY
In order to get personal key necessary for update please provide us serial number and MAC address of your HC2 at [email protected]. Please also attach statement that you have accepted terms of disclaimer.
FEEDBACK
We will appreciate your feedback on our bugtracker at
Thank you for your interest in alpha version and willingness to participate in the development of Fibaro!
  • Answers 264
  • Created
  • Last Reply
Limited storage on USB? Hopefully we will have cloud storage soon? Then backup icons?
I still have a 500GB external hard disk I could connect to the USB port. Plenty of room there!
Would like to avoid plugging stuff in to be honest
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> cloud makes sense! And i have a funny feeling the guys may even be thinking about it?
Don't like clouds. I hate leaving data on external servers. You never know how this data is protected or used. There are already to many cloud services out there. I have plenty of storage in my network to store a few icons localy.
i am only on about storing icons on the cloud
/emoticons/default_icon_wink.gif" alt=";-)" /> not your username/passwords/room id/devices etc...
Believe me, when fibaro starts with a cloud, they will store everything in the cloud.
surely the solution is to allow backups to be stored at another location, outside of the fibaro box. Cloud however is not to my liking, for the reasons outlined by mvrekum.
Alternatively, I'd be happy for Fibaro to sell bigger usb storage. with the recovery version baselined to say 4.0 (when it is released). Assuming its < £20.
Guest jcs10
Hello !
I liked to test the new version, but too much things need to be adapted on my side and I don't have time right now to do this.
So -> Recovery mode, and I get :
Some recovery files missing or corrupted.
How can I solve this ?
Best regards,
Jean-Christophe
One way to fix this is if Fibaro fixes are Dropbox plug-in, so when a reinstall is made on HC2 u login to HC2 and gos to plugin and login to Dropbox plugin and thels HC2 al my own icons is on Dropbox so u haw a virtual disk mounted on HC2 so backups al plugin settings to ur Dropbox account, this is 1 way to fix it, it's up to Fibaro to implement it or if HC2 plugin api has the abilities so a plugin dev can make the plugin
just a simple option to download/upload data from Hc2 to your own network will also be fine..
Hi guys wants to upgrade to the alpha version kindly the send personal key to upgrade.
Send your request as per instructions in first post.
No one answered Shad's
Anynews regarding the ZXT120?
When do you expect this AMAZING update is ready for public?
I am so enthusiastic!
Hello !
Best regards,
Jean-Christophe
Bad luck... call support could be a failed USB. If you have no copy it is a unit return.
I have same problem - no recovery possible, but Im not in worry - I think it is software issue somehow.
Can someone reply to this question ?
I really want to use this summer my air conditioner with my HC2 .......
No idea. Don't have the module.
candrea77, We got that device on our list TO DO but i can't say when we gonna add it
Lauri, It's more hardware problem with pendrives, we must add some tool who gonna check recovery to saw problems before you will need use recovery mode with option fix recovery pendrive if possible
io.open functional in new version ?
because i want to read csv or txt files from share (not web server) for reading of Weather Display datas
This is a very urgent request. Not only for me.
I am new to using the smart home, but when I bought the equipment, one of the requirements was to support the IR transmitters. Your system does not work with them. Frankly, I thought to buy vera just because they support ir
