Update 3.901 ALPHA for HC2
HC2 3.901 Alpha
Alpha version is designed for user testing.
Installation shall be performed only after reading and fully accepting following terms.
CHANGELOG
- introduction to the plugins (Denon Amplifier, LG Bluray, ONKYO Amplifier, Philips Bluray, Pioneer Amplifier, Samsung TV, Sonos, Sony Bluray, Sony TV)
- new improved Z-Wave engine
- cooperation with Z-Wave locks
- extended functionality of sensors (tamper support)
- extended support of Fibaro Smoke Sensor
- extended support of Fibaro Motion Sensor
- possibility of hiding devices
- possibility of disabling devices
- multithreading
- many backend improvements
IMPORTANT
In order to update to 3.901 alpha Home Center 2 must be first updated to version 3.591 beta.
It is recommended to make a backup before updating to alpha version.
Downgrading back to stable requires full recovery and restoring backup.
UPDATE PROCESS
1. To update to alpha make sure that you are locally logged as admin on your HC2.
2. Type the following address in your web browser:
http:///services/startAlphaUpgrade.php?key=
and press Enter.
3. Update screen with progress bar should appear.
Please be patient whilst update to alpha version as it takes more time than usually because of conversion process.
DISCLAIMER
Fibar Group Sp. z o.o. allows free use of this software in its “as-is” condition. Fibar Group Sp. z o.o. disclaims any liability of any kind for any damages whatsoever resulting from the use of this software
This is an alpha release, and active development is on-going. The platform might be unstable and is not final and should not be used in production.
PERSONAL KEY
In order to get personal key necessary for update please provide us serial number and MAC address of your HC2 at [email protected]. Please also attach statement that you have accepted terms of disclaimer.
FEEDBACK
We will appreciate your feedback on our bugtracker at
Thank you for your interest in alpha version and willingness to participate in the development of Fibaro!
  • Answers 264
  • Created
  • Last Reply
lukas.polivka, do they was configured good before conversion?
looks like conversion was crash
is possible to give me remote access to that hc2 to check log from conversion?
The devices were OK except some of the battery operated devices were offline.
Sending you a PM...
When can we expect alpha version 2 to be released?
Yes because I want to use my motion sensor alpha version 2 would be nice
Does the NorthQ power reader work for any one in the Alpha? Mine is only showing as a z-wave device. While it states correct what z-wave version and producer it is from the value is not shown anywhere... Andrew can this be fixed?
No it won't work the haven't implemented the support in this alpha but a Fibaro Dev told me the ar working on implementing support in a later Fibaro HC2 update
Does anyone have IP cameras working on alpha?
I purchased my first ipcam but can't get it to display through my HC2 but I can view/operate it from my browser.
FOSCAM FI8910E
FOSCAM FI8910E
from this
tested with non-alpha version, please try this parameter :
FOSCAM
F18620
F18904W
F18905W
FI8907W
FI8910W
F18918W
F19805W
F19821W
JPG URL: cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USER&pwd=PASSWORD
MJPG stream URL: cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=USER&pwd=PASSWORD
Turning left URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveLeft&usr=USER&pwd=PASSWORD
Turning right URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveRight&usr=USER&pwd=PASSWORD
Turning up URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveUp&usr=USER&pwd=PASSWORD
Turning down URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveDown&usr=USER&pwd=PASSWORD
Stop movement URL: cgi-bin/CGIProxy.fcgi?cmd=ptzStopRun&usr=USER&pwd=PASSWORD
Let us know if it work with your camera
Paxion, all my cameras works great with alpha version
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> (i use Vivotek IP Cam)
I just noticed that it is not possible to switch devices from a Virtual device. It worked before but not in the Alpha. (Probably the reason that Automatic lights virtual device doesn't work anymore).
Has anyone tried to add Satel Integra with this alpha version?
I had a (rare) opportunity to test that yesterday - connection test was OK, the panel was added and the model identified correctly (128), the popup progress bar finished on 100% (reading configuration etc.) but no zones / inputs / outputs appeared. I have tried rebooting the HC2 and reconfiguring the panel in HC2 to no avail.
I don't have access to the Satel panel anymore so I cannot help you further with the tests at this time.
I use Satel Integra with the Alpha (updated from stable) and my Satel work BUT i confirm: no zones / inputs / outputs appeared. Fibaro know the problem
OK, thanks, I missed that.
What should I do to recover my HC2 to latest stable version but recovery doesnt work any more?
(Some recovery files missing or corrupted.)
Lauri, you should do a full recovery (1.xx -> 3.5x -> 3.590), you do this? may be a problem with the pen drive...
Guest Lode
Lauri,
I had that same problem last year.
While trying to recover did you have an inproper shutdown of your HC ?
Or did you have to unplug it because there was no response anymore ?
I'm almost sure that this caused my problem and also to others.
FOSCAM FI8910E
from this
FOSCAM
F18620
F18904W
F18905W
FI8907W
FI8910W
F18918W
F19805W
F19821W
replaced all the lines and still same result. No video. I tried to view it through my HC2 on multiple browsers and the fibaro (android) app. all give black screens but when I enter the IP address into my browser the video stream shows up immediately.
are there settings on my camera i'm suppose to enable?
Lauri,
Recovery mode starts and then stays for 40% and error comes up: Some recovery files missing or corrupted. I have tried this multiple times but always same result.
Lauri
Guest Lode
Yep....i know that...very annoying !
I had to return my HC
Lauri,
Lauri
Can't u make a copy of a new recovery stick, from ur web shop?
[ Added: 2014-04-21, 11:07 ]
What settings did u us to setup vivotec? And model?
