Netatmo plug-in
Guest Lode
Guest Lode
Is this why Netatmo plug-in stops working after about 3 hours ?
Fibaro HC2 asks for too much data which is not allowed by the Netatmo API. They should increase the interval.
Lode, per dawiinci,
.. 4.031 release notes ..
Known issues:
Power Mettering may not work properly for some devices
Net Atmo plugin may stop working after few hours due API limits
UBS Temperature is not visivble on iPhone/iPad client
RGBW Controler may not work propery when used in in/out mode
Alarm Panel doesn't work in some specific configurations
Cheers,
al.
Guest solarium
    API limits ...
    No! Due to lack of optimisation and due to abuse of netatmo API ...
    Extract from Netatmo Dev :
    The user limit is here to prevent one user to break your app. However, the limit is quite high. Usually, reaching this limit is due to a bad design of your app.
    User limit
    50 requests every 10 seconds
    500 requests every hour
    Please fix it. It's a real need for many users !
    it is fixed in 4.032 we added option pooling
    oh great news. Do not suppose you will share WHEN is it due?
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> But I am glad it is fixed
    on begin next week
    Guest Lode
    on begin next week
    Great.........even working on Saturday Andrew ?
    Guest solarium
    Good news, thanks for the feedback !
    Thanks Andrew I appreciate your hard work!
    Seems to be fixed, thank you.
    For me, still not working after about 3 hours...
    Using 300 seconds pooling...
    I am still testing, have set to 360. But general note - if you use the same APP ID and secret for other stuff - you may still be blocked - this is netatmo api limitation. Make sure you create a new APP id/secret just for fibaro (and not a shared one you also use in Weather underground or other app). I think it should do the trick.
    I have a separate APP for HC2, and also disabled the other APP that was using my account.
    Still not working...
    I really don't think this is a Netatmo API limitation...
    Even using the GETMEASURE method to retrieve the data, in my specific case there are 4 modules (2 Netatmo stations with indoor and outdoor modules), with the default 60 seconds pooling, there are 60 (queries/hour) * 4 (devices) = 240 queries/hour.
    This is well below the Netatmo API limit of 500 requests/hour/user
    Also, once the plugin "crash", why it's not resuming normal operation after some time, but it's working again after you restart the HC2?!
    And why, using any pooling setting (60 - 360), the plugin stops reporting values after the same time every time (around 3 hours)?!
    The limit of Netatmo API is per hour so logically, if there was a problem with exceeding the API limits, it should stop working in the first hour, not after 3...
    Yes finally it's the same for me
    You are actually right, I have set the poling to 15 mins and even then the plugin stopped working after 3 hours..... this is bad
    So, the same for all of us. I become really disapointed
    not working ...
