Hi guys!
I'm experiencing a strange thing with my fibaro motion sensor (with zipabox, not HC2): I configured the luminance threshold at 20lux.. so I expect that sensor report me the lux value only with a >20lux increment or decrement.
But in my logs I see that the sensor report me many many many times the lux value, also with only 1 lux change!
Obviously the battery is draining so fast..
Any of you with the same issue? (sensor fw v.2.6)
I'm trying to understand that there's something bad with the sensor or is a zipabox fail in send configuration to the device.
thanks!!
Guest chaicka
Bug 2762 @
You may want to add your input. I didn't know it affects other z-wave controller too. Based on your post, it does seems to be the Fibaro motion sensor device itself is the cause.
