Entering recovery mode (factory reset)
j.nowacki
Due to numerous requests I decided to describe the recovery procedure for our controllers. Recovery mode allows you to bring controller to out-of-the box state, with the firmware version it was shipped with to you. There is no way to go back to version older that the one you got device with originally.
Entering recovery mode on Home Center 2:
1. Unplug your device from power.
2. Hold down the recovery button (with a little "+" on it )
3. Plug the device back, still holding the recovery button
4. Release button as soon as diodes start to blink from left to right (opposite direction as usually during boot up), enter device configuration page, it should look like this:
Entering recovery mode on Home Center Lite:
Procedure is the same as in Home Center 2, only difference is that diodes blink in different manner, but you still need to release recovery button as soon as they start to light up.
Holding recovery button for too long may cause controller to enter static IP mode. In that case one can attach it to computer directly with RJ45 connector, adjust his own network settings (IP in the same pool and default gateway 192.168.81.1) and perform recovery this way.
