I am using the Double Relay to control non-dimmable ceiling lights. It's easier to use the double relay since you can control two circuits with just one module.
But a great inconvenience occurs when using the Fibaro Mobile App. The relays are all listed under "EQUIPMENT" category. Is there any way of selecting which category the modules show up in?
I would love to see certain Relays in the "LIGHTING" category. Is there anyway of doing this?
Thanks.
Hi
In Web GUI go to Advanc​ed properties of the controlled light and change Controlled Device to Lighting
Go to advanced tab of the relay and set the controlled device to "Lighting"
    Thanks a lot guys. Working fine now.
    I am planning to use the HC2 with about 120 Fibaro Modules spread over an area of 12,500 sq.ft. (Basement + Ground Floor + First Floor). All the walls are clay-bricks, and all the roofs are concrete. Does anyone have any experience with such conditions. Will one HC2 be enough to handle all the z-wave traffic?
    I belive someone here in this forum have fitted an old stone cottage without any major problems. Remember to build the mesh network with mains powered units 'inside' and out and start with the units closest to the hc2 and work your way outwards. I suspect but can't confirm that gen5 devices can talk gen5 between themself even in a gen3 network and thus should get you a better cover through the thickest walls. If that doesn't work then perhaps you will need a slave bridge.
    Thanks guys, I will try first to use only one HC2. If I don't get the results, I'll try with a couple of HCLs. The house is about a month away from completion. Will share the experience once it's done.
    Post removed due to second thoughts.
