As Fibaro has no external keypad system to arm or disarm the alarm, the only way to work is with the tablet.
Is there a way to let your tablet (android) make a sound notification when arming the alarm or when entering the building when the alarm is armed?
/emoticons/default_icon_arrow.gif" alt=":arrow:" /> Maybe it's a nice feature in the future?
If the screen is on of the tablet and the Fibaro app is open, then there is a beep sounding (make sure you set the volume of the tablet to max).
Unfortunately no sound when arming the alarm. I made a scene which turns on a led strip for a second to let me know the status of my sensors. If whole house is armed, then the led will be red for a second. When I disarm the alarm, it will be green for a second (and purple when only my door/window sensors are armed (and not the motion sensors).
Ive created a scene sending me push notification when arming and android shouter app speaks it aloud - actually all the notifications what I see as usefull as simple beep of a push message can be easily not heard
  • 3 weeks later...
    Could you tell me which app it is that you use? I cannot find it in google play. Thanks
    /emoticons/default_icon_question.gif" alt=":?:" />
    Here you are:
    • 4 weeks later...
    Well I've tried the shouter app and it doesn't work at all... alles settings are ok on my phone and still nothing.
    But this
    works fine, only it says that app name and not the message content.
    There should be a better option.. but which one.
    Might be Android version issue, on my older HTC One also did not speak the message as sush, now on M8 works great...
