I've got many roller shutter 2 modules mounted and they work fine (except the calibration problem I wrote about in another post).
They are all mounted on the right side. One of them however in mounted on the left side (I've split the balcony blinds in 2 parts) and it seems that the Fibaro module interprets its open/close status so it tells it's closed when it's opened and viceversa.
Didn't see any parameter in the manual, is there something I can do about it?
Thanks,
Dem
Hi Dem,
sorry i don't get your question. Is the Status just shown wrongly in the HC2 GUI, or does the Switch really Switch the other way round. If it switches the other way reound, why don't you just Change the order of the cable from the Switch to the actor?
kandetvara
    Yes I will have to test changing the wiring, was wondering if there was a configuration parameter or hc2 configuration to do so... will let you know how it goes...
    thanks!
    Dem
    Hello, changing the wiring solved the problem.
    As a suggestion for Fibaro a software (or configuration) solution could be handy anyway...
    Thanks!
    Dem
