Alex 32
I have one problem:
I tried to install the new dimmer 2.
Everything worked fine so far (inclusion, automatic detection).
I have two momentary switches. If I use one of them controlling light works fine.
I am having two light in a row (two lamps at different positions).
The dimmer 2 module is connected to L, N. The output of switch 1 is connected to S1 (the other switch is connected to the first switch via
Light 1 is connected to O, than to the second light and back to neutral.
(So phase is connected to L of the module and input to the switches, neutral lead to N and end of second light, output of switch is connected to S1 and this "O" from the module is connected to the first light)
Now the problem:
If I switch on the lights via app or web page it goes on to the dimming value I want. but only for very short time (less than a second).
So it switches off directly.
If I repeat this it happens again. But after the third or fourth time the light stays on.
After switching it off again and waiting for a minute (I have not measured this) I can reproduce this behaviour.
What have I done wrong?
Any more details needed?
60
19
17
Sep 3
23
Sep 16
16
Sep 2
12
Sep 10
10
Alex 64 posts
petergebruers 60 posts
sjauquet 19 posts
Igy 17 posts
Sep 3 2015
Sep 16 2015
Sep 2 2015
Sep 10 2015
sjauquet
So I have found one way it seems to "works" If I remove the S1 wire from the second switch it magically doesn't turn off the light when I try to turn on from the phone app... But... I cannot turn on
Alex
It looks like it has something to do with Sx. I have disconnected S1 and now I can properly control the dimmer by web frontend.
petergebruers
That's good news! If you find the time, could you please find out more about that switch? I'm intrigued by the fact that it doesn't have a "potential free output" = relay output like mechanical switch
263 answers to this question
