Alex 26
I have one problem:
I tried to install the new dimmer 2.
Everything worked fine so far (inclusion, automatic detection).
I have two momentary switches. If I use one of them controlling light works fine.
I am having two light in a row (two lamps at different positions).
The dimmer 2 module is connected to L, N. The output of switch 1 is connected to S1 (the other switch is connected to the first switch via
Light 1 is connected to O, than to the second light and back to neutral.
(So phase is connected to L of the module and input to the switches, neutral lead to N and end of second light, output of switch is connected to S1 and this "O" from the module is connected to the first light)
Now the problem:
If I switch on the lights via app or web page it goes on to the dimming value I want. but only for very short time (less than a second).
So it switches off directly.
If I repeat this it happens again. But after the third or fourth time the light stays on.
After switching it off again and waiting for a minute (I have not measured this) I can reproduce this behaviour.
What have I done wrong?
Any more details needed?
60
64
17
Sep 3
23
Sep 16
16
Sep 2
12
Sep 10
10
sjauquet 19 posts
petergebruers 60 posts
Alex 64 posts
Igy 17 posts
Sep 3 2015
Sep 16 2015
Sep 2 2015
Sep 10 2015
Alex
It looks like it has something to do with Sx. I have disconnected S1 and now I can properly control the dimmer by web frontend.
Alex
I only have to remove the wires to the other two switches (or all of them) from S1. Than everything is fine with the light (except the bars-problem). LUA will work fine in this mode. I am thinking
sjauquet
So I have found one way it seems to "works" If I remove the S1 wire from the second switch it magically doesn't turn off the light when I try to turn on from the phone app... But... I cannot turn on
259 answers to this question
