Gardena 24V irrigation valve
Hi
Has anyone tried to integrate Gardena 24V valve like this one
  with fibaro? I will have 3 valves and thinking how to best deal with it? Would it be possible to controll them with RGBW controller and integrate into sprinklers panel?
I will have also main valve 230V that i could integrate with Siprinkler if RGBW would not be possible so integration is not an issue (I can controll the RGBW separately) - would just need to know if RGBW would work with this Gardena Valve
I think you may have the answer? If you can't use rgb then you have to use at least 2 regular relays and one input sensor. IE you have to buy 3 units instead of one...
@joystick this is the answer i got when i asked fibaro about rgbw and sprinkler panel.
  Jędrzej Nowacki 11 May 15
Dear Sir,
Sorry, but as far as I concern we do not plan to include RGBW into sprinkler panel. Of course hardware itself can be used for such purposes with proper circuit connected to it. Also some independent scene or Virtual Device can be always implemented to do the job but it will require some coding skills.
If you will have any additional questions please feel free to ask us!
Dear Sir,
Hm, that's really odd,  I bought the RGBW Relay because I was checking Fibaro Website on irrigation:
, where they say that the RGBW Controller is for garden watering... I do not own RGBW leds.... so I am going to return that damn thing.
Really annoying, because it could acutally be so easy, right?
cheers
joystick
