Has anyone had any experience with a wall plug doing this?
I can include & remove from the system, it seems to respond to the commands from the GUI, but there is no "click", nor does it turn on anything connected to it.
I have tried to reset it, but holding the button for 15-20 seconds, as described in the manual, doesn't get me a yellow ring.
Help would be appreciated.
If that happens right after plugging the device in it is most likely hardware issue, please start warranty procedure - support will assist you if need help in that.
  • 3 weeks later...
    thanks, i sorted it with my retailer.
