Feature request #1: This forum should have a defined part of the forum for feature requests
Feature request #2: The possibility to include a numerical or string variable in notifications would significantly expand the possibilities. In a simple form it would make it possible to learn from a message in the phone/iPad how many times the phone rang, a door opened etc. In a more extended context it would add the possibilty to fully define the message in the notification from a scene.
I requested this about... 3 years ago
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> pretty sure its hiding on bugzilla somewhere! but a great idea none the less... +1
this can be done in an interactive notification..
    True, but such a notification is only visible from within the app if I got it right.
    A variable would allow push/email/SMS messages to display more relevant information.
    can you pls share an example, Ive tried today with no success - I wanted to have the second level message as variable ( current temp from a multisensor ), but it did not work - in the notification complete line was missing....
    i dont know if this is what you are after, but i have done this as an example
    %% properties
    81 value
    %% globals
    local lux = fibaro:getValue(81, "value")
    fibaro:debug(lux)
    fibaro:call(12, 'sendPush', lux)
    12 is my phone ID
    81 is my lux level sensor (aeon multisensor)
    every time the lux level changes i get a notification with a new actual value....
    Yes that would work I believe...
    /emoticons/default_icon_smile.gif" alt=":-)" /> A bit more complex as it involves LUA but good enough. Will test it.
    Thanks!
