I successfully installed my fibaro motion sensor and I got 3 devices registered in my HC Lite: motion, temperature and luminosity sensor.
The problem is that after some time the icon for the motion sensor is now like a broken image (please see attachment).
The motion sensor flashes its light every time I get detected but it is not reporting it to the HC Lite. It seems some kind of configuration problem. Do you have any ideas of how to fix this?
do you use firmware 4.x?
    HCL software version is 3.601
    Motion sensor version is 2.6
    Not sure how to check firmware version
    i thought there were problems with 3,6 and the fibaro pirs, updating to 4.x should do the trick if you dare
    i was running 3.601 for a long while with 3 Fibaro motion sensors running just fine. I have since upgraded to v4 as well. All are working still.
    However.
    1 of them did not handle the upgrade well and had to exclude and include it again. After that, all was good. This being a very basic troubleshooting tip, I imagine you have tried it already?
