Lua in VD and scene acts different?
Im trying to control my foscam IP camera (PTZ and other) over the http commands. From any regular browser its a pice of cake. I would like to create virtual device where each button will represent specific command for camera control. I succeeded to create a scene with LUA to execute the commands:
%% properties
%% globals
local httpClient = net.HTTPClient();
httpClient:request('
However when I use the same code in VD with LUA, it doesn't work. I would like to avoid creating 10 scenes and call the scenes from VD, I would like to execute the code directly from VD. Is it possible?
Thanx for any advice.
4 answers to this question
    Thank you boerremk, but it didn't work. Tried to adjust the code based on other device I found on forum:
    CAM = Net.FHttp("192.168.1.51", "88")
    HWSResponse = CAM:GET('/cgi-bin/CGIProxy.fcgi?cmd=ptzGotoPresetPoint&name=Vchod&usr=AAA&pwd=BBB')
    Now it works perfectly.
    Thanks for directing me to the solution
    Try something like:
    response, status, errorCode = CAM:GET('/cgi-bin/CGIProxy.fcgi?cmd=ptzGotoPresetPoint&name=Vchod&usr=AAA&pwd=BBB%27)')
    if ( errorCode == 0 )
    then
      fibaro:log("transfer OK");
    else
      fibaro:log("transfer failed");
    You're welcome.
    I see why it didn't work. sorry I didn't notice it before, but If you removed %27) from the CAM:GET line it would do the trick:
    response, status, errorCode = CAM:GET('/cgi-bin/CGIProxy.fcgi?cmd=ptzGotoPresetPoint&name=Vchod&usr=AAA&pwd=BBB')
    I like to check if no error occured, that is why I check on errorCode.
    I did that too. But no succes.
