Guest fja
I've installed a lot of Danfoss valves, and setup zones a.o.
One thing I don't understand is the 'timing' issues.. Seems that scheduled setting changes get delayed.
I've set polling interval as recommended - but that as I understand is whow often HC2 polls the device. Also in advanced device setting there is as 'wake up interval' - which should then be how often the device checks in to HC2.
So: What is purpose of the time dropdown on main devices view??? It's just belov temp setting dropdown. It defaults to '0' - but can be changed in 15 minute increments.
.... Why??
Is this the cause for command delays??
