I have a Thermo-Floor / Heatit Multireg thermostat controlling my floor heating. I was disappointed that it does not support power usage.
So I wonder if it would be possible to somehow add to the device with LUA or a separate virtual device that accumulates wattage for the time it was active?
I have not done very much LUA coding to know if this would be possible. Is it any point at pursuing this at all?
An alternative would be to use an external actuator associated with the thermostat that supports power usage. But it would be more expensive and I'm not sure there is room in the wall box.
Regards
Stian
