I have a Yale lock and a Fibaro door sensor which i need help to make a auto lock scene with.
The yale lock has a auto lock after 30 seconds which is good, but it will lock even if the door is open. So I have disabled this and made a scene on my HC2 instead.
This is what I want to achieve.
1.       IF lock is open for 30 seconds or more
2.       AND the door is closed for 3 minutes or more
3.       THEN lock
It must also lock in the instance that the lock was opened but the door wasn't, i.e. the door has not open/closed to trigger the three minute count down.
​I built a scene as below but it doesn't work, can anyone suggest where I am going wrong?
I made a simple scene as below that says if front door is safe for 0 seconds then lock after 180 seconds, this works fine however if the door doesn't open/close then it never triggers.
Any help or suggestions much appreciated.
Thanks,
Karl
8 answers to this question
Guest chaicka
I doubt the Yale Z-wave door lock actually feed status info back to HC on regular time interval. I don't think HC even polls it at regular interval too. But I may be wrong.
    I doubt the Yale Z-wave door lock actually feed status info back to HC on regular interval. I don't think HC even polls it at regular interval too.
    Interesting OK so perhaps that's why its not working?
    The HC2 always shows the correct status of it, so it knows when its locked or unlocked.
    I tried this one too which should trigger but no luck either
    1. IF lock is open (0 seconds)
    2. AND the door is safe (0 seconds)
    3. THEN lock after 180 seconds
    Guest chaicka
    I have not look deeper into how the Yale lock's z-wave works since little is mentioned or documented.
    Based on my limited understanding, battery-operated devices normally do not support polling or reporting status back to controller. It may only support base-command-set which means when the lock is physically unlock, it sends a base-set signal to controller its status and that's it.
    Try to see if all the timing perimeters are set to zero and see if it works. If it does, that means the scene logic is ok but something else is preventing it from making the right assessment when timing is added to the logic.
    Add-On:
    You may want to create separate LUA script to query device info, last breached/status change, etc info to see what gets returned.
    Guest chaicka
    I wish I can help more but the Yale lock I have access to is connected to a HCL which cannot run LUA script.
    Hmmm...Do you see any entry in the event logs about the Yale lock open or close? I checked the site with Yale lock I have access to/manage, there is no entry in event log at all. Something does not quite add up.
    I've had a strange problem. I can connect my Yale lock to the HC2 but I can't tell the Yale lock to lock and unlock. On the HC2 it says transfer ok but nothing happens.
    My firmware is 4.080.
    Any help guys
    Any help guys
    Hey there, I had the same problem but simple fix, remove the device and re add but when you add it you need to hit the secure add device option or similar which is below the normal add button
    I Love you.. It works now. I'm on a deadline with the client and you saved my life.
    Thanks all. Very interesting thread.
    Have the following challenge:
    - Yale lock has been added to the HC2 in secure mode and I can remotely lock/unlock it
    - however, the reliability of both the lock/unlock process as well as of the display of the 'locked/unlocked' status is VERY unreliable
    - this makes is very hard using the lock/unlock in a scene
    - for example, my 'good night' scene is meant to automatically lock the door and the 'good morning' scene is meant to automatically unlock. Given that the lock quite often does not unlock in the morning, the HC2 goes ahead and starts the 'leaving home' scene which arms all the devices, etc.
    - I have found that using repeat commands/loops like while..do don't work either, given that the locked/unlocked status is also quite unreliable
    Has anyone else come across this?
    Any idea how to write the unlock/unlock scenes to overcome this problem and control the lock more reliably?
    Any help would be highly appreciated.
    Thanks!
