for some reason since today morning the weather is not working for my city anymore
at exact same time on 3 HC2s and 1 HCL completely different values:
on HC2 with v4.056
Temp 11°C
Hum. 62%
Wind 9km/h
on HC2 with v4.072 Beta
Temp 5°C
Hum. 87%
Wind 4km/h
on HC2 with v4.080
Temp 7°C
Hum. 69%
Wind 6km/h
on HCL with v4.080
Temp 7°C
Hum. 75%
Wind 11km/h
all of them have exact the same settings, i did changed them of course to test different location, rebooted, refreshed, etc.
only two located in same network, the other two have different internet providers, routing, etc.
all using proper DNS (8.8.8.8), of course tested with other DNS as well
on all /api/devices/3 is showing the displayed data (so no cache, memory, etc. issue)
... and of course data of none of them is what yahoo weather is showing :\
    well, Yahoo changed something :
    "To increase the security measure and better serving our YDN customers, weather data source will enforce OAuth 1 starting March 15, 2016. Please update your API calls with OAuth 1 enabled (via the OAuth /v1/yql end point if using YQL) using your Yahoo App key and secret"
    Same issue and I cant find the solution so far
    well, there is no solution for now, Fibaro will have to update the code.
    The current code is doing first
    * from geo.places where text="city"'&format=xml
    to get the WOEID, and that part is working, then checking weather based on the WOEID (and that is what yahoo changed), with
    As the code is within encrypted php, from user perspective there is nothing one can do, except wait of course.
    But i'm sure Fibaro will fix that asap.
    I cant believe that system like Fibaro can not rely on weather informaton provider. Even more surprising is , that they wont fix it from day to day. Scenes that are depended on weather info are useless untill they fix it.
    actually when you google a bit, you will find out that lot of websites (e.g. my golf club) rely on yahoo weather, and currently they do have exact the same problem - no weather information at all :\
    Even more surprising is , that they wont fix it from day to day. Scenes that are depended on weather info are useless until they fix it.
    hmm, in poland (and btw, in slovakia as well, so you should know it?!) they have public holidays since friday, and yahoo weather stopped to work on friday evening.
    Thanx for the answer, you are right. Im quite an optimistic to expect 24/7 support
    Perfect time to provide an open solution so one can choose weather provider!
    Actualy still no response from Fibaro, official support not even here on the forum. It a shame :- (
    Response from Fibaro support: "Yes, unfortunately the API was changed via yahoo so the integration also has to be change. We analyzed it and we notified our developers about this issue. They should create a new integration script in order to restore this functionality. The solution should be available in one of the upcoming weeks. We apologize for inconvenience"
    My only concern, it will take few weeks???
    Lack of information is the biggest problem with fibaro. Firmware version 4.081 beta is out and there is no mention of solution for this problem with yahoo weather. Can anyone confirm that this problem is solved? It seems to me that for my area problem still exists.
    I installed 4.081 Beta a few days ago and still have the weather problem. No changes so far.
    4.081 BETA is not corrected for the Yahoo weather API change - Fibaro has not solved this.
    of course not, the major part of beta 4.081 was compiled before the weather stopped to work.
    Yahoo is still allowing, but slow updating data, access via direct query (without checking WOEID first), but this is not satisfying, so we have to wait for permanent solution from Fibaro.
    Now imagine that you have scene that is using weather data. And fibaro is not able to update FW to fix this issue of functionality that is one of the basic for almost 2 weeks!!!!. Irrigation gone, heating based on outside temperature gone, roller shutter behavior based on weather gone...
    Im quite a surprised that only a few of users comply here on the forum about this.
    Yahoo weather has never been accurate for me, and I'm using my own data (Netatmo) for all the weather controlling stuff.
    Same here, it would be nice if we could choose to see that data on the ipad or tablet app main interface.
    +11111111111111 same problem for me!!!!
    We know about a problem and working on it
