Help ! My Motion Sensor did not have any parameters setting installed.
I've just bought a new HC2 and some modules to play with.
All the modules are properly installed, except this one Motion Sensor that frustrated me !
The device installation went fine (i presume), but when i go to advance tab, i cannot see any parameters setting installed. (screenshot attached).
I also tried to renaming the device, but it stuck at loading bar for forever.
NOTE:
- I've tried to delete and adding the MS module again for like 5 times, but still not fixed.
- Also tried to reset the Zwave already.
- My HC2 software Version is 4.056
Is this Motion sensor that i got is faulty ? Or Should i update my HC2 to newest software version?
though i've read a lot of bad reviews on this forum for the new software version.
Any help would be appreciated.. Thank you !
    Phew, Fixed it by upgrading the HC2 software to 4.080 version.
    Thanks everyone !
    Your motion sensor is not connected properly. Probably you place it somewhere where it could not connect directly to your HC2. Bring it near to your HC, and first delete it from system. During deletion you may press B-button on it three times. When it is removed from network then add it again using instructions provided but make sure it is near HC2 because for this action it must be able to communicate to HC2 directly. After it is added properly you can install it on place.
    I've deleted the motion sensor and re-add it again. this time i placed it next to my HC 2. but still no result..
    weird issue... is upgrading the HC version will solve this issue?
