Q1.  3. Meh, it's OK
Q2.  1. Stability
        5. Diagnostics
       11. More forum support, more active responses from Fibaro to users.
       18. An occasional overview of the direction ...
Q3.  4. I'm happy coding LUA from scratch
(great hope: "Q2.  23.  global functions")
Great idea to put this together.
@Fibaro: I see some moves you made in the recent past and I am really happy that you do that. Really hope you can hold up that energy and keep on listening to the user base.
Q1. How satisfied are you with your Fibaro System Scale 1-5 ;
    between 3 and 4 on my side.
Q2. What would YOU like to see as a focus on in the near future ;
     Prio 1:
      1.
      2.
      5.
      21.
     Prio 2:
      3. (might improve feedback quality and not so many "disappointed" messages
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> )
      15. (would say - maybe limit the number of new functionality so that new versions are out faster)
      new: provide hot fixes between stable versions (e.g. like the yahoo weather issue.... took very long to get a solution because there was no hot fix available...)
Q3. How would you describe your mad coder skillz :
     4.
Thanks a lot for the initiative.
May LUA bit with us all
Q1 = 4
Q2 = 1, 4, 5 and Non hardware protected-USB-Stick solution. Let us use ordinary USB-stick
Q3 = 3
Edited by RH_Dreambox
I still didn't vote and I will wait to see where this go. I was satisfied at the beginning, but not any more so much after 8 months. Deletion of devices by gateway on its own is very big issue and makes this system just a toy for children. Latest problems also with push messages and e-mails stop working, another BIG minus. My confidence is now completely lost in this system after second time HC2 deleted important devices.
If I vote now it would be completely negative on all accounts. Since I still have some confidence in Fibaro team (not gateway!!) that they are capable of resolving mentioned problems I decided to wait and give them a chance to make it more than just a toy.
  • 3 weeks later...
Q1:
2 - Not totally dissatisfied
Q2:
2 - Security (https support for login from local network, apps are sending non secure http authorisations to ml.fibaro.com every 5 minutes)
5 - Diagnostics ( Logging, mapping, process lists, script loads etc )
9 - Some attention to the Bugzilla ( I've stopped posting as it seems a mute point )
11 - More forum support, more active responses from Fibaro to users
18 - An occasional overview of the direction Fibaro are embarking upon
- Maybe you can add some options:
+ 23 - More user control and advanced options for privacy related issues (use of custom emailserver, opt-out Google analytics, open access to HC2 by SSH etc.)
+ 24 - Support for common used protocols and devices (SMB/NFS, SMTP, SNMP, SSH, WOL for HC2 startup, BlueTooth-dongle support, external storage devices support etc.)
Q3:
Between 3 and 4: I'm happy coding LUA from scratch, but still learning.
2.
  • stability
  • privacy
  • configuration download/upload as XML
  • better tooling for development (currently using external editor, copy/paste and git for version control) - for Lua scripts
  • better debugging facilities, basic stuff like stepping through code!! Off-machine emulator would be nice
  • function libraries (copy/paste is not a solution)
  • remove the restrictions on using certain functions in Virtual Devices (json, network) and allow them to be used anywhere
  • did I say privacy
3. 4 (I'm a coder
/emoticons/default_icon_biggrin.gif" alt=":-D" /> )
    Thanks folks,
     I understand Fibaro are still keeping an eye on this thread, so although this is by no means definitive, and it's annoying not having a proper poll available, the feedback is continuing to be useful.
    Cheers,
    al.
    • 2 months later...
    3- Meh, it's ok
    1- Stability
    1- Stability
    1- Stability
    100 - Reliability !
    Q3. How would you describe your mad coder skillz ;
    10- hey guys there are also owners of HCL without LUA !
    • 4 weeks later...
    1. I'm not at all satisfied
    1. Stability
    2. I can tinker and code most things with blocks.
    Thanks folks, Fibaro are still watching, if nothing else they can get a sense of what the community is looking for.
    Cheers,
    al.
    • 3 weeks later...
    End-year update (using alandree's data from last page - he is the host his data are cannonicall mine are ilustrative)
    allso sorry Flowy i am not able to interpret your Q2 and Q3.
    Additionall request for annyone posting - use numbers to determine which question you are including Q2, it gets messy with bulletpoints (sorry t-fibaro if i misinterpreted yours)
    Q1 (satisfaction)
    1            6 (completly dissatisfied)
    2            15
    3            21
    4            28
    5            4 (completly satisfied)
    Q2
    1. Stability....................................................................................................................................................................................................................................................................................................................................................................45
    2. Security....................................................................................................................................................................................................................................................................................................................................................................15
    3. A Closed or 'Opt in' only Beta program ( removes some of the negative sentiment, but also pressures a company into releases that work without excuse ! )...........................................................................................................................10
    4. Plugins ( Seriously ! )...............................................................................................................................................................................................................................................................................................................................................25
    5. Diagnostics ( Logging, mapping, process lists, script loads etc ).............................................................................................................................................................................................................................................................................42
    6. Hardware Compatibility ( Support for my ZWave XXXXX ( Insert your not working item here and refer to # 9 & # 10 ))........................................................................................................................................................................................14
    7. Software Flexibility ( Phones and Tablet apps)..........................................................................................................................................................................................................................................................................................................3
    8. Upload-able device parameters so we can share between us without having to wait for an update.........................................................................................................................................................................................................................7
    9. Some attention to the Bugzilla ( I've stopped posting as it seems a mute point ).....................................................................................................................................................................................................................................................18
    10. A ( banging my own drum ) Wiki so we can collect and share working device lists, work arounds and code snippets............................................................................................................................................................................................10
    11. More forum support, more active responses from Fibaro to users............................................................................................................................................................................................................................................................................14
    12. Better support ( phone or teamview / email ) for users................................................................................................................................................................................................................................................................................................9
    13. GPS functionality / improvement ( lets face it without a tesla powerwall your kinda screwed running it at the mo )...................................................................................................................................................................................................5
    14. Lilli, someone needs to give some love to Lilli and turn her into something actually usable and useful. Cortana, OK Siri and OK Google have proven it can be done very very well ! ( Tay .. not so much ..
      )...............................................7
    15. More Beta's .. poke em out after each change and lets see how they go....................................................................................................................................................................................................................................................................2
    16. Flexibility of App design ( layout and control, not just re arranging but floorplan layouts etc )...................................................................................................................................................................................................................................14
    17. More Fibaro hardware like Swipe, speaker et..............................................................................................................................................................................................................................................................................................................4
    18. An occasional overview of the direction Fibaro are embarking upon. ( Keep the secrets secret, but throw a dog a bone once in a while ! ).............................................................................................................................................................9
    19. Better camera support..................................................................................................................................................................................................................................................................................................................................................5
    20. Better secure device support........................................................................................................................................................................................................................................................................................................................................1
    21. Better Alarm and Security support................................................................................................................................................................................................................................................................................................................................5
    22. Bring on the HC3 ?.......................................................................................................................................................................................................................................................................................................................................................0
    (unofficiall ones untill host of this discussion decides to include them on front page)
    23 - More user control and advanced options for privacy related issues (use of custom emailserver, opt-out Google analytics, open access to HC2 by SSH etc.)...................................................................................................................................1
    24 - Support for common used protocols and devices (SMB/NFS, SMTP, SNMP, SSH, WOL for HC2 startup, BlueTooth-dongle support, external storage devices support....................................................................................................................1
    Q3
    1            3 (i am not coding)
    2            5
    3            35
    4            16
    5            4 (Whoa)
    Edited by Kuba13
    FORMATING
          5. I love it, I'm completely satisfied
    1. Plugins ( Seriously ! )
    2. Diagnostics ( Logging, mapping, process lists, script loads etc )
    3. A ( banging my own drum ) Wiki so we can collect and share working device lists, work arounds and code snippets.
    4. GPS functionality / improvement ( lets face it without a tesla powerwall your kinda screwed running it at the mo )
    5. Lilli, someone needs to give some love to Lilli and turn her into something actually usable and useful. Cortana, OK Siri and OK Google have proven it can be done very very well ! ( Tay .. not so much ..
    6. More Fibaro hardware like Swipe, speaker etc
    7. Better camera support.
    8. Better secure device support.
    9. Better Alarm and Security support.
    10. Bring on the HC3 ?
    I'm sure this list could continue forever, but there you go ..
    1. I'm comfortable using LUA with a bit of direction and a nudge ..
    Finally after one year of playing with my Fibaro devices I can add my votes to this thread. My HC2 had some hiccups in the past but now I know most of them were caused by me :P Maybe that could be avoided if there is better guides with examples how to than just so basic and mostly unhelpful
     especially for novices. Is it so hard to add some better explanation of functions and more examples over there?
    So Q1 reflects that I'am satisfied with current box. My HC is stable especially when I'm away on work so I can't play with it :) It works smoothly for hole month without any problems, maybe just little ones but solely caused by me! Maybe it is because I use only one scene running all the time? Maybe it is because I reduced network traffic by moving refresh code for HUE lamps from main loop to button? I can't really prove that, but before doing so I had same problems that are repeatedly posted here under Community support. I still have few sensors that are not so reliable like one Fibaro motion sensor and three Fibaro door/window sensors, but thats about it.
    Q2 reflects my wishes for the future, hopefully not distant one!
    Q3 well, I'am still learning and there is a lot to digest with LUA.
    • 3 weeks later...
    Answers:-
    {1{4},2{1,2,3,4,11,13,18,21},3{4}}
    21 hours ago, shaunfrost said:
    Answers:-
    is that
    Q1
    4
    Q2
    1
    2
    3
    4
    11
    13
    18
    21
    Q3
    4
    2 hours ago, Kuba13 said:
    is that
    Q1
    4
    Q2
    1
    2
    3
    4
    11
    13
    18
    21
    Q3
    4
    Yep.
    @Kuba13 You're amazing with jumping on this thread ;-)
    @shaunfrost Thanks for the feedback !
    Cheers,
    al.
    Cheers,
    al.
    Since Fibaro staff claims that its important to get feedback ill make damn sure they do .)
    It is for the good of community. It is for the good fo system and it is for the good of Fibaro.
    Allso i think its worth to make some statistics every once in a while to help people see trends. Please can you do recount, as mentioned before i am not so sure about few relatively recent posts - i LOVED your previously comprehenssive stats complete with charts.
    Q1: 4
    Q2: 1 - 5, 7 - 10, 15, 16, 18 - 22
    Q3: 3
    @Fibaro team: Throw us some bones. Meaning some info about new products, that could feed our speculations.
    About point number 5 in Q2: I envy to countries with US frequency. They can buy this
    Edited by jakub.jezek
    Next opportunity I get I'll pop some data up.
    Cheers,
    al.
    • 1 month later...
    Thanks @alandee.... my 2c worth
    1. I'm pretty satisfied
    1. Stability & Security
    2. Software Flexibility ( Phones and Tablet apps)
    3. Upload-able device parameters so we can share between us without having to wait for an update
    4. A ( banging my own drum ) Wiki so we can collect and share working device lists, work arounds and code snippets.
    5. An occasional overview of the direction Fibaro are embarking upon. ( Keep the secrets secret, but throw a dog a bone once in a while ! )
    6. Better camera support.
