more than 11 sonos VD's running successful ???
Strange one for you ...
I have 14 sonos zones or varying types and when I add the 12th the VD doesn't work or display anything. I think its a number related issue as I removed a few and added a few different ones and always couldn't seem to add more than 11
I tried the usual, adding/removing VD many times, fixed IP's on the zones, all SW up to date, power cycled impacted zones, removed any 'funny' characters in the room or device names
running 4.080 and it's the 1.0.1b beta sonos remote
Does anybody have more that 11 zones with VD and all running okay ?
-Frank
4 answers to this question
Hey Frank,
Did you try any of my suggestions?
Cheers
Aleks
    Hey Frank,
    Cheers
    Aleks
    Yes - some and thanks for the suggestions...
    I took a look and the main loop doesn't have any errors when it doesn't work.
    I also took a look at the code and couldn't see any reference that may contribute the the limitation
    I did try and set up the last three zones using an earlier version of the VD (0.0.8, I think ) and worked. (I dont know why)
    I was going to try and see of the 1.0.0 would work and take it from there...
    It doesn't solve the issue but does get me a workaround for a while
    I'm also going to keep an eye on Krikoff and see if he is close to a new release
    will keep peopleposted
    Please do, I´m not there yet - but closing...
    glad you are part way there and at least have it working for now.
    we all wait patiently for krikroff's update.
