seiq 31
Is there a way to determine whether a virtual device slider was changed by physically moving the slider or whether it was updated with LUA?
This is for a now playing progress bar. In the slider's LUA script I want to ignore when the slider was updated by the main loop LUA code.
fibaro:getSourceTrigger() sadly doesn't work for virtual devices.
UPDATE:
Issue resolved.
Use fibaro:call(id, "setProperty", "ui.Slider1.value", position) to change the value and position of a slider without running the code in the slider.
The slider on the web interface may not move without refreshing the page when this is called but it does work.
Edited by seiqLink to post
