Richard H 0
I have a Dimmer 2 that I'm using with 16x 5w Megaman dimmable LED GU10s (141391). It's in a 3-wire configuration. I'm using them with a Vera Edge but I don't think that's important for my issue.
My issue is that it doesn't dim down anywhere low enough. At full brightness they report 87 watts, but at 1% dim, they are currently reporting 20.3 watts which is still pretty bright! Also, the dim range is far from linear. There is almost no decrease in light/power dropping from 100% to 50%. It's only when I get below about 40% that there is much noticeable decrease.
I've done a couple of re-calibrates but it doesn't seem to help. After doing so Variable 1 (min brightness) is set to 10 and 2 (max) is set to 46. I've tried setting variable one lower but the value doesn't seem to stay.
Would the Dimmer Bypass 2 maybe help me out here?
Richard
14 answers to this question
