Was searching to display the date and time parts and came across this
and used on conjunction with the normal os.date you can display/use any part of a date/time
gives
and the time is
might save other newbee's like myself from too much head scratching
-Frank
nice find. Thank you
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> I think i found some uses for %w
  • 5 months later...
    • 1 month later...
    Hi Frank or everyone else :)
    I was wondering if you have experience or solution in doing a "calculation" with the following example as I like to reduce (or extend) the sunriseHour value with e.g. one hour ? (sunriseHour2 = sunriseHour - ????)
    sunriseHour = fibaro:getValue(1,'sunriseHour')
    I could me miles away but was just looking at "sunriise sunset" vd part of @Sankotronic "timed based events"scene set up
    The vd looks like it has the calculation your looking for on the sunrise +.- button
    just a long shot
    Id copy and paste it but you prob get it more in context if you downloaded it
    Edited by Jamie mccrostie
    just a long shot
    @Jamie mccrostie
    yes, your correct. His code does this calculation and also has multiple examples of time compare/adjustment
    • 1 year later...
    " to "
    Temat został przeniesiony z "
    " do "
