Fibaro - Please add support for Remotec ZRC90 (template attached)
Hi Fibaro,
Please add support for this device as a matter of urgency please.
it's a 8 button scene controller/master that I suspect is likely to get very popular considering its form factor and price.
I included it with my HC2 but have no control over the scenes it activates
I download the template from the HC2 after I added it and have attached it here
on the box is it also referred to as BW8510EU
Thanks in advance
-Frank
    device ID dump is
    I'm still not sure what you mean by the thrid ask....
    Third menu is the devices menu (correct?)
    this is what I see - not sure about triggers
    /public/style_images/master/attachicon.gif" alt="attachicon.gif" />
    okay - I got it to work
    This is the scene code I used
    Device got in manual mark z-wave plus. and require Association command, AGI, Central Scene, both HC support it so they should work w/o our help
    First please check
    - in group 1 of association is setting to HC (device id 1)
    - is device is configured on true
    - in lua please check is device send any action central scene (key pressed)
    First please check
    yes to the first query
    I'm not sure how to check the other two suggestions ...
    2nd - hc2_ip/api/devices/id_of_devices
    3rd frm left menu chose your device and clik on all trigers key pressed, later write fibaro:debug("i't works"); then just start presing keys if you see text in debug that mean that is working
    device ID dump is
    Hi all. Will this one work with HCL as well? If there is no template, how do I know which scene activation id I need to add in the HCL scene's?
    Re the HCL query I'm not sure mainly because I have never owned one..
    Sorry
    -F
    Guest Veil
    Im trying to get this to work as well.
    Id dump of the Remotec unit
    Configuring is showing as true.
    I tried the lua code below:
    I do get the code "it works, key 1" when the button is pressed. So there is communication. Is there anyway I can get the buttons to show up in block scenes? I'm terrible at LUA.
    Sorry - I have never worked in block scenes.
    I only started to learn lua 12 months ago and it's easy enough to pick up the basics.. once you get there you'll never look back...
    -frank
    Tried this and only get the debug when starting the scene, nothing with the button press.
    Steps I have gone through are
    - press W & L buttons and select add a device, which added the keypad as device 129, although in the parameter section is says ID 130, and in the advanced section on the advanced page, it says Node ID 29....
    - Created a new scene with the following code:
    %% properties
    %% events
    %% globals
    %% properties
    %% events
    129 CentralSceneEvent 1 Pressed
    %% globals
    if (
     ( true )
    or
    then
      fibaro:debug("it works, key 1")
    Then when you press Start, it outputs "[Debug} 12:48:34: It works, key 1" but no additional when pressing key 1
    What am I missing? Really need this device!
    %% properties
    %% events
    %% globals
    %% properties
    %% events
    %% globals
    if (
     ( true )
    or
    then
    I'll try and take a look later this evening.....
    %% properties
    %% events
    %% globals
    %% properties
    %% events
    %% globals
    if (
     ( true )
    or
    then
    You have one too many scene headers. You need to remove one and it should work. Code should look like this:
    According to AutoFrank's template each button has this actions: Pressed, Released, HeldDown, Pressed2 so above scene should be triggered when key No. 1 is pressed and released ones in 1 second. Correct ID should be the one that is on right side of the device Icon shown on general tab.
    Thanks. Not sure why it is not the same number as it used to add the device, but then it's not the only strange thing with this system!:-D
    Thanks, that now works. Do you do one scene for each action, or can you have one long scene for any action for the device?
    Don't really understand the code, would be great if they added a template, but in meantime ...
    in the code above, I presume you can create several additional events, like '129 CentralSceneEvent 2 Pressed','129 CentralSceneEvent 3 Pressed' etc. but then how do you determine which button was pressed/held/etc.?
    @AutoFrank has provided complete solution on this link so pleas check:
    First please check
    Would be better if the template was added so that it can be easily used. Is it possible to add the template at the user end?
    Spectacular! Thanks to both of you.
    Cool, let us know if you still need help ...
    I also have a ZRC-90 and i found this youtube:
    i dont get it at work, this is what i get, can somebody please help?
    Hello @Chundo
    @Chundo
    Can you provide the debug result for fibaro:debug(json.encode(sa)) ?
    I do believe you're hitting "Start" button in the scene. Am I right?
    When You do this the trigger is not the device but the scene itself, so there the parameters you try to compare just don't exist. Use the device to run the scene.
    As a ex-game dev... looking at this code makes me fill bad... But I'm not here to teach anyone how to write readable and/or efficient code...
