looking for outdoor motion sensor recommendation
I'm looking for a recommendation for a reliable outdoor motion sensor
I have 2 everspring SP103 units and since batteries don't like the cold, I'm running them on an external 5v supply but they are very unreliable. I've tried to set the parameter to "not sleep" but no luck.
Does anybody know of a mains powered outdoor zwave sensor ( so it doesn't go to sleep like a battery one) or one that can be powered from a USB port like the (aeotec multisensor - 2015)
Is the aeotec multisensor reliable or does anybody have some other suggestions
.. or perhaps I'm just not using the SP103 correctly
-F
Link to post
9 answers to this question
Currently using two of those Everspring SP103 (on batteries) myself as well.
One of them seems reliable as to where the other was often reported as dead. After z-wave mesh rebuilding it (seems) to work (so far - fingers crossed/fiercely knocking on wood/etc
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> )
If there are other ones I would be interested as well.
Link to post
Guest fat
What about something like this? It has a dry context output which you could possibly connect to a binary sensor
Link to post
  • What about something like this? It has a dry context output which you could possibly connect to a binary sensor
    interesting one
    I took one of my SP103 and gave it a slightly bigger USB PSU and reset/re-included it so I'll see how I go with that
    perhaps I could also check if it was dead and issue a 'reactivate' through a scene
    It's looks like there aren't many of these types of device on the market
    Link to post
    I have been using the Aeon Labs multisensor for a few years successfully. I am living in Sweden so the winter is somewhat cold. However, when it broke down about a year ago I contacted support. Reasoning that it was mounted under a roof outdoor I claimed it must have been a product issue.
    The answer I got was that any temperatures below 10 degrees C is extreme and not supported.
    Subsequently I am also looking for a better solution....
    Link to post
    Just a status update on my SP103:
    after "re-meshing" the z-wave network, then one which went dead before is up and running for some days now. The other one is operating without problems from the beginning.
    so far it seems ok to use them.
    Link to post
    just use the fibaro motion sensor
    I'm using them under a small roof without any issue. If necessary you can make a power supply that connects to the batt. terminals.
    Link to post
  • I took my 2 SP103 and reset them, soldered cables to the pcb from a 2 m good quality USB lead and hey presto they seem to be stable for the last week or so. I'm now thinking that they got a bit messed up with a previous HC2 revision update and I didn't notice it.
    I'll keep track of them a bit better now and see how they do.
    Of all the sensors this is one gap that seems to exist across the suppliers..
    ...more later
    -F
    Link to post
