Have anybody tried Hikvision Intercom with HC2?
Guest Roman
Have you tried hikvision intercom devices with Fibaro HC2?
Looks like they support SIP and pretty cheap.
afaik (based on manual) they does not support mjpeg
Guest Roman
    Yes, you are right. But this is not a problem. Because Fibaro HC2 has build in Asterisk server. It means Fibaro supports SIP clients like this intercom.
    Here our small test with Bas-IP, but it's much more expensive.
    • 4 weeks later...
    Unfortunately, the stream of the doorbell is only H264 and no second stream available for MJPEG, i can't get it connected.
    DS-KV8102-IM
    I have another model of HIKVISION cameras hooked to Fibaro.
    I entered the following path :
    Streaming/channels/1/picture
    both for MJPG and JPG and set refresh rate of 3 sec.
    Give it a try ...
    Not working for the intercom
    /emoticons/default_icon_sad.gif" alt=":-(" />, working with other cameras of hikvision but not the Intercom.
    Anyone an other idea?
    Also not working for the Intercom cam =
    Streaming/Channels/1/Picture?videoResolutionWidth=1920&videoResolutionHeight=1080
    Streaming/channels/1/httppreview
    • 2 years later...
    Hi Marco, Just curious if you managed to connect the hikvision intercom to your fibaro system?
