Guest cberbecaru
I'm facing a very strange issue with remote connection on Android app which drives me crazy from over a month. I have several Android phones which all behave in similar manner:
HTC One M8s, Samsung Galaxy S6 both on Android 6
HTC One M7 on Android 5
The problem is that remote connection will not work anymore AFTER a successfully local connection, failing with "Invalid login or password" message. There are 2 situations:
1. Install the app while connected to LAN. It will connect locally, but it will NOT connect remotely after that
2. Install the app while on mobile network. It will connect remotely and stay on remote connection even when connected to LAN. As soon as the Settings/Choose HC is opened, a toast pops: HC IP address updated, and after that no more remote connection is possible
Obviously the problem is not in the configuration of remote access because the app can connect remotely.
I used an app to sniff the requests made by the app and here comes the strange thing: While in mobile network (or other network), the app make a request to dom.fibaro.com which is successful, but after that, for some reason, it will try to login to the LOCAL IP (192.168.1.200) while on foreign network, which, of course fails. The above happens only after a successful local access (that is, after the IP update thing).
I used to stay on remote to circumvent this problem, but since I added 2 cameras to the system this is no longer feasible.
Edited by cberbecaruTop Posters For This Question
13
9
6
3
Feb 9
4
Dec 16
4
Dec 5
3
Aug 25
3
DinoKustas 13 posts
T.Konopka 9 posts
mobbie 6 posts
Razvan 3 posts
Feb 9 2017
Dec 16 2016
Dec 5 2016
Aug 25 2017
72 answers to this question
