Hopefully this an easy one...
I have a HEM ( I think its a 1, 60A 1 clamp) and I'm running 4.100
It's on the main feed into my consumer electricity panel for my house
In the energy consumption panel I can see the watts and also in the device view ( watts and accumulated kwh)
If I check through the API I can see the volts / Amps value but the watts  and kwh are showing as 0.00
KWH/WATTS
VOLTS
AMPS
Does anybody know how to read the watts successfully or is there another clamp meter that works reliably with the HC2
I recently got a 2.6 kw PV array installed and I'm trying to monitor what I am using v generating
any help appreciated
-f
4 answers to this question
    I sorted this out and created a VD, code running in main loop with supporting labels as follows
    thisId = fibaro:getSelfId();
    HEM device
    Popp wall plug with energy meter
    Quote
    Thanks!
    I have a 3-clamp HEM so I had to add some more lines, but it works nice :-)
    glad it helped
    I have the same issue, see separate thread:
    In my case, the device is a z-uno which counts the pulses on my electrical meter and reports them into the HC2 as two channels, one for power and one for energy. Both are displayed as "0.00" in the UI sadlly enough.
