I am using the universal binary sensor from fibaro for my doorbell. One of the outputs are connected to a relay for the doorbell to sound. Input is connected by the doorbell.
How can i make a scene where i can block the output from the sensor in the evening, so that the doorbell will not sound... but for example a light will flash in the livingroom?
You can't. The output follows the input, always... What you need is a an extra relay module, with floating (aka potential free contacts). You are not the first, and won't be the last person that assumes that you can control the outputs of this sensor module.
